09-08-2020
20:44
17:50
09-08-2020
20:44
17:50
My silent alarm function has disappeared from my app now that I have done the latest update. Everything I try doesnt bring it back.
Is anyone else experiencing this?
Has anyone solved this mystery?
09-09-2020 00:29
09-09-2020 00:29
The update has moved the alarms from the phone app to the Charge 3. On the Charge 3 main screen, swipe left until you see the alarms app.
09-09-2020 00:29
09-09-2020 00:29
09-11-2020 20:37
09-11-2020 20:37
when I swipe I see no option for alarm at all. All I can find is DND OR SLEEP. When I swipe nothing happens at all.
Best Answer09-11-2020 20:55
09-11-2020 20:55
Yes I have the same problem. Still looking for help.
Best Answer09-11-2020 21:01
09-11-2020 21:01
Got it thanks but the new alarm really sucks. Wake set 11:30 so it wakes between 11 or 11:30
Best Answer09-12-2020 00:11
09-12-2020 00:11
@Charge-2 did you enable smart wake by mistake?
"When enabled, Smart Wake attempts to find the best time to wake you starting 30 minutes before the alarm time you set. It avoids waking you during deep sleep so you're more likely to wake up feeling refreshed."
Best Answer10-24-2020 03:00
10-24-2020 03:00
I swipe across, find the alarm, click on it and it disappears!
