01-10-2017
21:38
04:24
JuanJoFitbit
01-10-2017
21:38
04:24
JuanJoFitbit
My charge 2 keeps waking me up at 12:30am and 1am every night telling me "it's time to go to bed". I'm already asleep, and it keeps doing this on a nightly basis! How do I make this stop? I can't find a way to do so at all, and I have to get up at 7am.
01-10-2017 23:35 - edited 01-10-2017 23:35
From the sleep tab of the app, go to the sleep settings page (cog at the top of the screen) and disable the reminders from there. That's the iOS method, anyway.
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
Mike | London, UK
07-17-2017 20:31
07-17-2017 20:31
What about when you've unpaired and no longer have your fitness tracker -- which (presumably) prevents you from seeing or interacting with the sleep tab?
07-18-2017 03:41
07-18-2017 03:41
If it is not connected to a fitbit account, tyat means your not using tye tracker. So i dont understand the question.
If the tracker is still bothering you, it will need to be setup to a fitbit accoujt, before this setting can be changed.
07-18-2017 06:42
07-18-2017 06:42
07-18-2017 09:01
07-18-2017 09:01
Sorry if I repeat anyone's answers.
You need to click on the sleep button and then click 'edit goal' (the button on my computer and phone is a circle with a shaded circle inside it-like a camera lens). There you can edit your bedtime goals and turn the reminders off. You can also turn reminders off on your fitbit by holding down the button, but I think that stops all of your notifications (incl. hourly activity)
07-18-2017 16:44
07-18-2017 16:44
Best Answer07-30-2017 19:52
07-30-2017 19:52
Any answer to this? i'm on the same boat..
had a fitbit charge hr, and the aria scale, i got rid of the charge but kept the scale, now i keep getting
reminders to goto sleep but i cant remove the reminder since the sleep tile doesnt show up anymore because i dont have the charge hr. I still have the app because i still have the aria scale
07-30-2017 20:32 - edited 03-25-2019 07:53
If you have removed the tracker and do not access the sleep tile my suggestion would be to reach out to fitbit. Link found inder help in the app or in the top right corner of this page.
03-24-2019 21:07
03-24-2019 21:07
I’m in the same boat too any answers yet!
Best Answer03-25-2019 07:56 - edited 03-25-2019 07:58
03-25-2019 09:03
03-25-2019 09:03
I believe we know that but once you remove the device the sleep option is no longer on your dash so there is no way to disable anything.
Best Answer03-25-2019 13:22
03-25-2019 13:22
@SunsetRunner you never mentioned that your device was removed, In that case I suggest what I suggested in the post above your last post, to contact Fitbit support. The other option would be to add a tracker to your account, even a borrowed tracker, remove the notification and return the tracker.
10-18-2019 00:15
10-18-2019 00:15
This also works for me on android.
Best Answer09-06-2021 21:02
09-06-2021 21:02
I'm in slightly better shape, since it tells me to go to sleep hours before I go to bed, but the reminder is turned off and I want it that way. Unfortunately, it still reminds me.
09-07-2021 22:06
09-07-2021 22:06
I’m having the same problem, but I have notifications turned off for the bedtime reminders. I even turned off the sleep goal option thinking that would help. It’s been happening ever since I updated the app to the newest version a few days ago. The alert only shows up on my phone as a push notification.
09-08-2021 13:21
09-08-2021 13:21
Have you turned off your sleep schedule?
Fitbit uses this as to remind of bedtime
09-08-2021 18:21
09-08-2021 18:21
I don’t have a sleep schedule set up on my app. As I said in my comment, I have the sleep goal and bedtime reminders turned off. This has only been happening since I did the update to the newest version of the app. Something tells me it might be a bug?
09-09-2021 17:24
09-09-2021 17:24
Welcome to the Fitbit Community, @ashlehman. It’s good to see you in the community, @Oregonmama and @Rich_Laue.
@Rich_Laue Thank you for your support.
@Oregonmama @ashlehman Thank you for sharing the details of the issue you’re experiencing. I appreciate your efforts and would like to confirm that this issue has been reported to our team and they are currently investigating it. Please keep an eye on this thread for updates.
See you around.
09-20-2021 19:11
09-20-2021 19:11
I’ve been having the same issue since the update and nothings turned on, it still is not fixed because it just happened again, it’s kinda frustrating cuz it’s happening at like 10pm and I’m never in bed before 2/3am
