08-18-2017
10:14
07:12
JuanJoFitbit
08-18-2017
10:14
07:12
JuanJoFitbit
I haven't biked for awhile because of a knee injury. Now, starting again, I can't remember how to turn on the timer for my bike ride.
08-18-2017 10:35 - edited 08-18-2017 10:43
Hey you @lwgordon, welcome to the forums! I'm happy to hear that you're ready to get back on track on your bike routines. I'll be glad to collaborate in this.
First-time setup on iOS:
First-time set up for Android
Now, when you're ready for tracking your biking routine:
Syncing your tracker stores the workout in your exercise history. There you can find additional stats and see your route if you used connected GPS.
Let me know if there's something else I can assist you with. I'm always around!
08-18-2017 10:39
08-18-2017 10:39
08-18-2017 13:54
08-18-2017 13:54
Or simply hop on the bike and start riding, Fitbit will detect your on the bike and log it.
01-23-2018 01:29
01-23-2018 01:29
I did my first ever pavement and road bike ride with a fitbit charge 2. On the activity, it has sporadic steps over the period I was on the bike. I thought the activity would show bike instead. I was expecting it to detect me on the bike.
01-23-2018 03:28
01-23-2018 03:28
@boot-it the steps come from the bouncing around of the handlebars. If your ride was at least 15 minutes, the default unless it was changed, the ride should have been detected. You could also manually start the bike mode.
01-23-2018 05:04
01-23-2018 05:04
05-22-2018 12:33
05-22-2018 12:33
How can this be the accepted solution if the only choices of exercise are hike, walk, or run? Which one do you choose when riding a bike? It seems a little silly. Why do you not just have the choice to start a bike ride so that there are no random steps inserted in the middle?
05-22-2018 17:06
05-22-2018 17:06
@cjonasson have you read the solution, and the question of how to track a bike ride?
Since we are in the Charge 2 hardware forum this question is about tracking the Bike Ride with the tracker and not the Fit it app, for as you say this can not be done in the app .
The solution is about how to use the Charge 2 to track a bicycle ride.
If your interested in tracking a bike ride with the Fitbit App. you might want to search the App board..
Another step would be to add a vote to the request .
05-23-2018 05:41
05-23-2018 05:41
05-23-2018 08:01
05-23-2018 08:01
Your Charge 2 may be setup to manually track up to seven types of exercises from a list of nineteen, bike ride is one of types exercises.
Let's look at fitbits help documents .
06-14-2018 20:22
06-14-2018 20:22
I'm biking for last 3 daydbut can't track my route or save the data.
I Sync my tracker but am unable to store the workout in my exercise history. I can't find any additional stats and see my route.
06-14-2018 22:59
06-14-2018 22:59
Hello @AmeetPrabhu. most bike rides should be automatically detected if you do nothing.
To get a map you will need to have your phone with you and manually start the bike recording on your wrist, as explained in the solution posted above. Is that what you are doing..
06-14-2018 23:07
06-14-2018 23:07
09-15-2019 13:50
09-15-2019 13:50
Hello I have the same issue but it is for mountain biking. There are only three choices on my iOS app for tracking: run, walk or hike. Ow do i had mountain biking to the choices?
thanks
09-15-2019 14:06
09-15-2019 14:06
@dogchinookdog let's look at the exercise options on the Charge 2. If you need to add bike, i posted a link to the help doc above.
03-06-2020 18:47
03-06-2020 18:47
After following all of your directions mine continues to say trying to connect. I’m not sure how to get it to finally connect so that I can see my biked route.
03-07-2020 12:06
03-07-2020 12:06
@Buck1982 I'm not sure which all instructions have been tried, or what type of phone you have.
04-22-2020 13:34
04-22-2020 13:34
Hello and thanks for listing all the steps to have the Fitbit track bike bides and include a map and distance and other stats. I have an iPhone 7 plus ios 13.4.1 and have taken all the listed steps (my phone was already set up correctly) but my Fitbit still does not reliably track with a map and distance. It used to for my walks and bike rides but the last time it did was April 4 (it's no the 22) and I have done walks and rides (including today) since. Today and all other days the unit said it was connected. I have also turned the phone on and off and turned Bluetooth off and back on (got this info from other Fitbit threads) and it doesn't make a difference. I no longer get a map or the distance. Where I ride is unobstructed from buildings and there is not a problem with the phone's broadband coverage or GPS. Please let me know what else I can do. Thank you.
04-22-2020 15:24
04-22-2020 15:24
I am frustrated as my Fitbit doesn’t track my biking. I tried to follow the “best answer,” but my Charge 2 tracker does not include biking or any other exercise options. Thus, I can’t set it to bike mode when I am biking. What am I doing wrong?
IowaBoy
