03-21-2016 18:14 - last edited on 09-06-2020 17:01 by MatthewFitbit
03-21-2016 23:15
03-21-2016 23:15
Your son needs to set up a new account (with his own email). He then adds your Charge as a new device and it will delete any data left on it and reassign it to his account. Your data will not be affected.
02-10-2018 02:16
02-10-2018 02:16
Hi ,
i want to give my old charge2 to my bf. I have received a replacement unit which I’m using now. I set up new account on his phone but it doesn’t recognise the device when searching for it? I have unlinked it from my Bluetooth. Any ideas?
02-10-2018 02:21
02-10-2018 02:21
@Magdiewagdie is his phone supported by fitbit? The list is at www.fitbit.com/devices
02-14-2020 06:23
02-14-2020 06:23
Do I have to delete my Alta from my phone before giving it to a family member
02-14-2020 06:25
02-14-2020 06:25
@Rosheldo to avoid potential issues I would remove it from your account in the fitbit app but also "forget" any link to the fitbit in your phone's bluetooth settings as this could block connection to their phone.
03-29-2020 07:35
03-29-2020 07:35
Hi- I am trying to do the same thing. I created a new account for my son (age 11), but when I select ‘Setup a new Device’ the only options it gives me are Ace and Ace 2...but I want to connect his account to my old Charge 2.
how can I connect his account to my old device?
04-01-2020 19:04
04-01-2020 19:04
is Alta the only type of device that will work with a ‘family member’ account for minors?
04-02-2020 00:20
04-02-2020 00:20
@ColoradoCool A child account only works with the Ace and Ace 2 trackers
02-10-2023 15:05
02-10-2023 15:05
I found it was important to “forget” the device on the old phone
