09-22-2016
11:28
05:04
JuanJoFitbit
09-22-2016
11:28
05:04
JuanJoFitbit
Hi,
Is there a way to turn of the notification for daily goal? It's kind of a waste of battery to me.
Thanks!
Moderator edit: format
03-08-2018 23:31
03-08-2018 23:31
In what way is it terrible?
Have you thought about letting the developers know your opinion by adding a suggestion to the feature request board?
No one else has thought of this yet.
03-09-2018 00:56 - edited 03-09-2018 00:57
In what way is not setting your goals accurately because you don’t randomly want your watch to start buzzing while you sleep kind of annoying?
I didn’t think that really needed to be explained.
I would like accurate goals set in the program.
I would like to not randomly be woken up.
The fact that i have to trick my watch instead of just turning that’s “feature” off is terrible.
Whenever I am interested, i can check my goal progress. I know how.
Thank you for the suggestion box link though, I didn’t know it’s it existed and suggested this “feature”.
03-09-2018 01:00 - edited 01-11-2019 05:45
My primary goal is set high enough that they don't get hit until after I wake up.
If I haven't hit my goal before going to bed I have never reached the goal once asleep. .
You could set the goal high enough that it is unreachable .
03-09-2018 01:05
03-09-2018 01:05
06-06-2018 10:53
06-06-2018 10:53
Hello,
I have the same problem, but for me the notification and fireworks typically occur when I'm about to fall asleep. It wakes me up. So, are you saying I have to set my goal higher? There is no way of turning this "end of day" notification off? If this is the solution, is Fitbit considering this on other models?
06-18-2018 10:34
06-18-2018 10:34
@mpacer Welcome to the Fitbit Community! I hope you're doing well! As you said this can't be turned off but you can vote for the idea in our Feature suggestions board. The more votes an idea gets the more likely the developers will try to implement it. Additionally you can change your goal to floors or calories or increase your step gaol so you don't get the notification at the end of the day.
Let me know how it goes!
Best Answer01-10-2019 23:54 - edited 01-11-2019 00:06
I want to turn off vibration on goals alert!
Don't think it would be such a great effort implementing this feature!
Regards
GP
01-11-2019 05:49
01-11-2019 05:49
Please remember that we are in the Fitbit user community and the best that your fellow Fitbit users will be able to do is give a workaround. Yes putting in an of switch might be easy, but since it might not be something your fellow Fitbit user will be able to do for you.
I hope you all have added your vote to the suggestion @AlvaroFitbit pointed to above.
09-16-2020 08:58
09-16-2020 08:58
It is one of my biggest hates about fitbit. I love having my concentration at work broken by a stupid vibration to tell me to go have a walk.
09-17-2020 05:28
09-17-2020 05:28
@Fedupwithnonsen , the vibration telling you to go take a walk is something you can definitely turn off! It’s called Reminders to Move. Many people like this feature that suggests taking at least 250 steps every hour, but if you don’t want to receive these reminders, on your app click on your Fitbit tracker icon and find “Reminders to Move” on the next screen. You can set the hours when you receive these reminders, or turn them off altogether.
I hope this helps. Welcome to the forums!
08-18-2021 15:08
08-18-2021 15:08
Several times these notifications have almost caused me to crash my bike. Please make a way to disable these! It is a serious safety issue to be distracted when we are moving.
08-18-2021 15:09
08-18-2021 15:09
It is not clear in the app how to adjust the target. I only see a setting for what it recognizes as an activity.
12-15-2022 13:22
12-15-2022 13:22
Perhaps already irrelevant, but for my Charge 5 I enabled "Do not disturb" and disabled "AZM notifications".
