10-21-2018
12:04
15:03
10-21-2018
12:04
15:03
Today I finally found that my charge 3 can show date now. However, I found that the feature that you can show the time by flip your wrist doesn't work on charge 3. How can I turn on that feature? It's very useful when you have only one hand free and want to see the time.
Thanks!
10-21-2018 13:37
10-21-2018 13:37
Press the button for a couple of seconds. It's the option on the top (Screen Wake). It toggles On/Off when you press it.
10-21-2018 12:26
10-21-2018 12:26
Go to settings and enable quick view.
Best Answer10-21-2018 13:00
10-21-2018 13:00
Can NOT find the settings for charge 3. Chinese language. Is it a setting for device or Account?
Best Answer10-21-2018 13:37
10-21-2018 13:37
10-21-2018 16:41
11-15-2018 14:22
11-15-2018 14:22
So simple when you know.... Thanks Joe002
Best Answer11-19-2018 07:56
11-19-2018 07:56
OMG I must have accidentally turned this off. Thanks!!
Best Answer12-27-2018 18:41
12-27-2018 18:41
Thanks bunches Joe
Best Answer01-05-2019 05:02
01-05-2019 05:02
Thank you.
Best Answer01-11-2019 04:41
01-11-2019 04:41
Cannot find that option on settings. Nor can I see it when I press button for a couple of seconds...
I’m in Sweden
Best Answer02-11-2019 10:23
02-11-2019 10:23
Thanks for the solution. It worked.
Best Answer02-11-2019 11:01
02-11-2019 11:01
@BarbroA, this option is not in Settings section of the Charge 3.... When you are on a face screen of the tracker, push haptic button on the left side long enough to feel 2 short vibrations - you'll get to 'Screen Wake' and 'Notifications' quick setting options. Tapping on each of them will turn them on or off.
03-06-2019 01:18
03-06-2019 01:18
Thank-you how easy was that
06-24-2019 05:49
06-24-2019 05:49
Took me a bit to turn it on... a picture would be very helpful.
When you hold the button it says "screen wake" and "notifications"
Touch the screen ABOVE "screen wake" and a little lightbulb shows up. NOW you're going to be able to flip your wrist.
If you touch around "screen wake" or "notifications", a different little icon shows up (or goes away) that controls notifications.
07-17-2019 01:29
07-17-2019 01:29
thanks maan!
Best Answer07-17-2019 01:55
07-17-2019 01:55
Best Answer08-13-2019 17:56
08-13-2019 17:56
Device. Press the button on the left side for 2 seconds, and tap “screen wake”. The light bulb icon should look “on”, without a slash thru it.
11-16-2019 15:20
11-16-2019 15:20
Thanks for the info about turning on the time motion activation
Best Answer12-25-2019 17:23
12-25-2019 17:23
Thank you! Thank you! Thank you! It was working a few days ago, then it stopped. I was getting so frustrated until I saw my question and answer on the community.fitbit.com.
Merry Christmas to me. Lol
Best Answer01-02-2020 08:37
01-02-2020 08:37
Thank you.
Best answer to my opinion!
