12-06-2016
07:09
10:26
12-06-2016
07:09
10:26
Hi
I have tried everything to get my charge 2 working with my new phone, or that failed, ANY phone.
I think the problem lies that my charge 2 is still connecting to my iPhones bluetooth, unfortunately my iPhone decided to die last night and now I cannot get it to turn on, if I could, I would disconnect my charge 2 from it's bluetooth, so it could be paired with my new phone, which is an Android Huawei p9 lite.
The things I have tried already:
- spoken with a fitbit technical advisor
- restarted the fitbit
- replaced the charge 2 with a new charge 2
- deleted/removed the account altogether
- restarted my p9 lite
- restarted my p9 bluetooth
None of these helped to find the device. I have since found out that fitbit do not support the P9 lite, however the fitbit specialist advised me that it may still work, it didn't.
I then tried to find the device via bluetooth on my friend's iPhone 6S - where I failed again.
Please help as I have only had the fitbit 2 months and I love using it 😞
12-06-2016 07:29
12-06-2016 07:29
@sicilyt, you should not have to worry about "unpairing" it from your old phone - since the phone won't turn on, its Bluetooth is not active and not able to connect to the Charge 2 tracker. To set it up on a new phone, you need to install the app, log into it with your current userid/password, then go to Account and "Set up a Device". Select Replace a device, which will remove your old tracker and install the new one - even if the "old" one and the "new" one are the same tracker, this will work to set it up on your new phone. You can also accomplish this with your computer.
01-28-2018 18:58
01-28-2018 18:58
I have been searching for weeks for this solution! Your help was exactly what I needed and really simple thanks.
Best Answer03-25-2018 07:24
03-25-2018 07:24
blsame problem i got a used fitbit and it wont connect to my devices
Best Answer03-25-2018 07:25
03-25-2018 07:25
you do realize the fitbit cant refresh so this wont work
@USAF-Larrywrote:@sicilyt, you should not have to worry about "unpairing" it from your old phone - since the phone won't turn on, its Bluetooth is not active and not able to connect to the Charge 2 tracker. To set it up on a new phone, you need to install the app, log into it with your current userid/password, then go to Account and "Set up a Device". Select Replace a device, which will remove your old tracker and install the new one - even if the "old" one and the "new" one are the same tracker, this will work to set it up on your new phone. You can also accomplish this with your computer.
Best Answer03-25-2018 07:29
03-25-2018 07:29
i have a used fitbit it wont connect to my device and it wont restart its dumb
Best Answer11-01-2018 12:37
11-01-2018 12:37
Same issue. My old iPhones screen is totally dead and the battery is, as far as I can tell, dead now. Can’t unbond my charge 2 so Bluetooth on my new iPhone won’t even see it. It won’t pair at all. Tried all suggestions short of full factory reset which is next but I’ll loose my step count for the day.
Best Answer01-04-2020 10:29
01-04-2020 10:29
Finally got my fitbit tarcker to work after following these instructions. Thanks for posting.
