01-22-2019
21:43
17:54
01-22-2019
21:43
17:54
I can't connect the charge 2 to my Samsung A6 plus
01-23-2019 04:40
01-23-2019 04:40
@ajaynanu9999 Welcome to the Fitbit Community! I hope you're doing well! Sorry to hear that your tracker isn't connecting with your phone. Your phone doesn't show as compatible but that doesn’t mean it won’t work it just means that it hasn’t been tested by our team. You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
Let me know how it goes!
