08-14-2022
23:52
09:07
AndreaFitbit
08-14-2022
23:52
09:07
AndreaFitbit
Does anyone find that the lightning your Fitbit is not working?
10-19-2022 23:20
10-19-2022 23:20
If you can make out something on the screen, your Fitbit is likely dimmed. Open the Settings app on your device. Tap Screen Brightness and change to Max (if available) or Normal from the options, or choose off the Dim Screen option. Also, check that Sleep Mode is not turned on–this mode automatically dims the screen
Regards,
Will
