06-12-2022
14:03
14:20
06-12-2022
14:03
14:20
I no longer receive text message alerts on my charge 4 ? I have had look through settings etc incase I turned something off inadvertently.
06-12-2022 18:02
06-12-2022 18:02
Hello @Sueo13
Let’s recheck your settings just in case something accidentally got changed. Of course first make sure your DND (do not disturb or sleep mode is on. Notifications will not come through if they are. I’m unaware if you use Android or iOS so I included both:
Android user:
Also open the Fitbit app, tap profile picture then scroll down and tap Charge 4 then scroll down and tap notifications. Make sure all your desired notifications are enabled. While on the same page tap App Notifications and make sure all your desired Apps are enabled. Once all your changes are made synce your Charge 4 to accept all the changes.
😃 I hope this works for you. Please come back and tell me how it went
