01-05-2020 10:13 - last edited on 09-08-2020 11:28 by
I lost my Fitbit in 2017 and I have no clue where it went. I have tried to find it from the apps and I couldn't. Does anyone know something that I should use? Any tips?
01-05-2020 10:25
01-05-2020 10:25
Hello @Doga111. Sorry, but after more than two years, finding your Fitbit would be hard to do. Only you know where it was when you last took it off your wrist. Your app can't help. There is no way, with a dead battery that you could locate it, unless you look all over the place, including your car, closet and linen cabinets. Seriously. after so long a time with a dead battery, expecting it come back to life and working properly would be a bit of a stretch. The good news is there are new styles of Fitbit available and you might want to take the time to check them out.
01-05-2020 11:52
01-05-2020 11:52
