I revoked myfitnesspal but want to set it up again
Can you help me restore my fitbit 2 accessing myfitness pal?? I accidentally revoked it in my settings and I do not know how to get it back!
13 REPLIES 13
am having problems with mfp aswell. It says connected but no steps or calories are syncing to it
@soverykeri21 @Lel45 Welcome to the Fitbit Community! I hope you're doing well!
@soverykeri21 in your case you just need to link them again and both should work as they used to. You can follow the instructions here.
@Lel45 you can also check the link I shared with @soverykeri21 but I wanted to add that there were some syncing issues from MFP that have been resolved so I would like to know if you are still having issues with this?
I look forward to your reply!
Alvaro | Community Moderator
Thankyou. They are back up and running. Cant remember exactly how I did it
lol. My only problem is when I deleted app and downloaded again I appear to
have lost previous data.
@Lel45 glad to hear that the apps are now syncing. How many days were lost after this issue? Have you contacted MFP to see if there is any update from their side? If there aren't many days or activities you could try logging them manually on MFP or wait if the account will update in the next few days.
Was having syncing issues and read that I needed to revoke MyFitnessPal. I did that and now I can’t get it back. Please help me restore this.
I'm having the same problem again at the minute. I'm not sure if it's the
app in general
I was going to revoke it as it wasn't sync in... But reading this I won't! Was syncing fine up until yesterday. Frustrating.
Having the same issue, revoked myfitnesspal and reconnected and still not syncing!
IV checked looks like my fitnesspal been down a couple of days . Going to
wait see what happens tomorrow
Thanks... Will hang on and hope it was an app upgrade... 🤞🤞
Hello everyone.
MyFitnessPal was having issues from their side syncing with Fitbit. They have diligently worked on this and fixed the issue. You can actually read their update in their help site here.
Let me know how it goes.
I done exactly the same thing when they stopped syncing and I was trying to sort it.
@Acklandp Welcome to the Fitbit Community! It's great to have you here!
Thank you for sharing your experience. What did you try in order to correct the issue and this it work? I ask as your post wasn't clear and this could help other members in the same situation.
See you around.
