01-28-2022
10:18
15:46
01-28-2022
10:18
15:46
Maybe there's something I'm not understanding, but it seems to me that just about all of the Charge 4 clock face options require you to tap a bunch of times to see your steps (or whichever stat you are most interested in).
I've found just one unattractive retro clock face where its display is all steps, all of the time.
Is there a way to just set all of the clock faces to only display steps, or choose your default stat that you're most interested in? Or must I be forced to incessantly tap through a bunch of stats I don't care about?
01-28-2022 10:24
01-28-2022 10:24
But after you tap through once to get to steps, doesn't it stay there?
01-28-2022 13:09
01-28-2022 13:09
No, it doesn't stay there. I have to tap through a bunch of stuff every time.
01-29-2022 08:24
01-29-2022 08:24
Are. You looking at the clock face? Or scrolling to the stats listing.
While the last stat on most faces should stay, I noticed tgathit is easy to inadvertantly tap and go to the next stat.
