01-04-2019
14:57
18:22
01-04-2019
14:57
18:22
Anyone else having difficultly in connecting a Charge2 replacement? My original failed and I was sent a replacement … for which it will not connect. I have been online and on the phone several times and have been told that there is an issue with the code and it may take several weeks to correct and I should just keep trying to connect every day and if it does not work -- I should call back and discuss. This sound like garbage.... so I am checking if anyone else is having the same issues.
01-04-2019 17:34
01-04-2019 17:34
I’m having the same issue. My replacement arrived today and it won’t sync with my iPhone or iPad. I’m not sure it’s charging while the set up screen appears on the Fitbit, the battery symbol never appears.
01-04-2019 18:31
01-04-2019 18:31
I’ve been dealing with this for almost 4 weeks now. It seems the replacement Charge 2s aren’t recognizable by Bluetooth. I think it’s a hardware issue and no update will fix it. Seems like FitBit is just giving us the runaround. A software issue wouldn’t keep the device
from being recognized by Bluetooth. Fitbit needs to step up a and resolve ASAP.
01-04-2019 19:38
01-04-2019 19:38
01-04-2019 23:50
01-04-2019 23:50
It your interested in help getting your charge 2 to sync, it might be easier if each starts a new thread and please include the type of device that is used to sync through.
01-05-2019 02:47 - edited 01-05-2019 02:50
It has nothing to do with the type of phone
peopleare using. It's a problem with the whole batch from which they keep sending charge2 replacements out to people.
01-05-2019 05:43
01-05-2019 05:43
01-14-2019 09:42
01-14-2019 09:42
