02-21-2019
13:02
11:22
02-21-2019
13:02
11:22
I've taken 2 water exercise classes in a local pool. It's for seniors. No diving, no jumping, just gentle movements. In both cases, my Charge 3 seemed dead after leaving the pool, no display, I tried to recharge it, it wouldn't accept any attempt at getting it going again.
After sitting overnight on the kitchen counter, it started working again. My guess is water got into it and stopped it from working. Is this the best I can expect from the Charge 3? If it's leaking water from gentle movements, I wouldn't call it "water resistant." Is there a method to dry out the device quickly? Or should I return it for a refund?
Thanks!
02-21-2019 16:44
02-21-2019 16:44
Hi @SunsetRunner No, that is not expected behaviour. I swim in mine with no problems. I will flag your post for a moderators assistance.
Helen | Western Australia
02-21-2019 16:44
02-21-2019 16:44
02-21-2019 17:12
02-21-2019 17:12
Thank you so much for your thoughts. I have been hopeful that the Charge 3 will perform as advertised. I am using water therapy more now, as I am recovering from a serious knee surgery. Thanks again! I'll wait patiently for additional responses!
02-21-2019 23:02
02-21-2019 23:02
This is exact same what happens to me. But I was only in the shower and my chsrge 3 is not working. Battery is not charging and it is very very hot when i am charging
02-22-2019 10:31
02-22-2019 10:31
Hey @SunsetRunner, welcome to the Community. @Nina100, it's great to see you around and @NellyG, thanks for the input.
@Nina100, upon checking with our support team, I was told that you have already created a case with them. I know they will be glad to help you out and provide you a solution.
@SunsetRunner, since the instructions provided didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Keep me posted.
02-22-2019 12:06
02-22-2019 12:06
Ok ,so must I just wait? Support team will contact me? Or what have I do now? @AlejandraFitbit @
02-24-2019 03:15
05-09-2019 18:11
05-09-2019 18:11
charge 3 is about as water proof than a boat with holes in it
07-26-2020 04:23
07-26-2020 04:23
I have my Charge 4 for almost a whole day. I check to make sure this model is “water resistant” and stand in a pool. At no point was I thrashing around and my hair never even got wet. I wasn’t in very long at all. The screen is blank and it appears to be dead. I left this out on the counter and it still doesn’t seem to be working. After assuming that water is in the device as it stopped when exposed to water, I pressed down on the display screen and a bead of water came out of one of the corners along the edge of the display. I am heartbroken! It was one glorious day of collecting data and logging water and food. So sad. Would love suggestions to get the water out and hope it will turn on again.
07-26-2020 07:02
07-26-2020 07:02
@JPTXPA (tagging because this forum does not make it clear who you are replying to - really weird design!)
Are you sure that drying out is what you want? You purchased a water-resistant device, so if yours is not water-resistant then it is defective, and as such I would expect a replacement. Even if you don't intend to expose it to water again, it has had water inside it so there is potentially corrosion damage in there, so why accept that and the accompanying risk of reduced lifespan for the device?
If you really would rather dry it and take your chances then put it in a sealed jar or bag filled with a dessicant to draw the moisture out and leave it for a couple of days. Silica gel is ideal, but if you don't have that (and few do) uncooked rice or raw cous cous will do the job (this is common advice to people who dunk non water-resistant phones). But I would just contact Fitbit or the vendor who sold it to you (which may depend on your local consumer laws) and get it replaced as it was defective when sold.
07-26-2020 07:32
07-26-2020 07:32
Thanks for the advice. I’m so disappointed. I will sadly return my Charge 4. Take care and thank you for your thoughts.
07-26-2020 12:44
07-26-2020 12:44
