Is it possible to change the Charge 2 battery?
Can you replace the battery in your charge 2 fitbit? Thanks.
3 REPLIES 3
No, the battery is not replaceable.
Welcome aboard @Staceypoole! As @JohnnyRow said, it is not possible to replace the Charge 2 battery, and I would't recommend you to try that out, because that type of damage can avoid the Fitbit warranty. So if you have inconveniences with your tracker's battery, let me know, and I will assist you with it.
Have a nice day!
Heydy | Community Moderator, Fitbit
Is there a way to change out the battery?  Right now a charge last about two days.
