08-06-2021 04:25
08-06-2021 04:25
At the moment when I use the treadmill I want to check my current heart beat rate and the only way I have to do that is to hold onto the support bar where the sensors are.
I would like to walk and swing my arms and still have a way of seeing my current heart beat rate.
I am using a charge 2 and the App on my iPhone at the moment and cannot see any way to do this.
Is it possible on this fitbit device?
If not is it possible on a later version of charger or another fitbit device?
08-06-2021 06:37
08-06-2021 06:37
How about setting your phone somewhere you can see the heart rate display there.
Best Answer08-06-2021 07:20
08-06-2021 07:20
I have tried the item scrolled down to the bottom that shows a heart beating and have confirmed it does change when I get active but it is a bit small for me to see if I put the phone on the shelf on the treadmill.
I will try that next time but was hoping for a focused screen that just showed the heartrate.
Thanks for the tip.
08-10-2021 04:28
08-10-2021 04:28
I have tried that and I can just about make out the numbers so I am good with that but would still like a bigger display of the heartbeat monitor.
Thank you for the solution.
