Is it possible to edit manual exercises on a Charge 3?
ANSWERED
Is it possible to edit incorrect manual exercise entries on a charge 3?
1 BEST ANSWER
Accepted Solutions
Hello @Rudepne. Welcome to the community forums!
If you refer to manually log activities, please note that you can edit or delete activities in your exercise history in the Fitbit app. Depending on the exercise, you can choose to edit the type of exercise, start and end times, distance covered, and calories burned. Note that you can only edit activities in the Fitbit app.
For more information, I recommend visiting the following link: How do I add, edit, or delete Fitbit data and activities?
Hope this helps.
Wilson M. | Community Moderator, Fitbit.
3 REPLIES 3
Hope this helps.
Thank you WilsonFitbit. Instructions worked perfect.
@Rudepne It's been a pleasure!
I'm glad to hear that the instructions helped!
Have a great day!
