Is it safe to spray paint my Charge 3?
Hi, I was wondering if it was safe enough to spray paint the band and the actual tracker itself (masking the screen and sensor) because i grew bored with my old black one and I'm not interested in buying a different color.
3 REPLIES 3
A warm welcome to the Community, @UltraRunner31.
Regarding your inquiry, I don't recommend to spray paint your tracker. Please checking our wear and care page and our warranty policy.
Let me know if you need anything else. 🙂
it’ll probably work for the band but i wouldn’t do it to the device itself.
I wouldn't recommend you to do that. Painting any gear related to technology can be a pretty difficult task, especially if you don't know how to do it. If you really want to do it, I would suggest you inform yourself about the type of paint that you need, since I am 100% sure that it has to be a special kind of paint. I am painting as a hobby, but I have only used numbered canvases like the ones from https://paintingbynumbersshop.com so far. Maybe, one day, I will be able to paint on different surfaces. My biggest dream is to be able to draw something on a huge wall with graffiti.
