12-20-2020
07:33
03:28
JuanJoFitbit
12-20-2020
07:33
03:28
JuanJoFitbit
I upgraded to Apple OS 11.1, and my Fitbit Charge 2 won't sync with computer. I get a message that the computer cannot find the wireless dingle. Is Fitbit not compatible with this latest Apple OS upgrade?
12-22-2020 03:25
12-22-2020 03:25
Hi @Achilla, welcome to our Fitbit Community. Your Charge 2 should be compatible with the latest Apple OS update.
Since your Fitbit device is not syncing with your computer, restart your computer and make sure that your computer has the most recent Fitbit app version installed. After this, please try the troubleshooting steps that are listed in this help article.
Finally, monitor your tracker during the next 24 hours and see if the issue gets fixed.
Keep me posted on the outcome.
Best Answer01-12-2021 10:55
01-12-2021 10:55
I just got off the phone with a FitBit Modertor and he told me Apple computer is NOT compatible with Fitbit to recognize the dongle for syncing to Big Slur OS for Mac. It appears that only apps for the phone and iPad are compatible for syncing. This is misleading! Which is it compatible or not compatible??
01-12-2021 11:12
01-12-2021 11:12
01-12-2021 12:36
01-12-2021 12:36
01-12-2021 17:48
01-12-2021 17:48
No it’s not. With 14.3, I get simplified sleep and my text messages not longer show on my Charge 2. Exactly when I upgraded
Best Answer01-12-2021 18:20
01-12-2021 18:20
Best Answer01-14-2021 05:04
01-14-2021 05:04
Best Answer01-14-2021 12:25
01-14-2021 12:25
I just upgraded from Mojave to Big Sur this week, & experienced 'can't find wireless dongle'/won't sync. Syncs with iPhone & iPad - frustrating, but at least now I know that it will never sync with my Mac. 😡
01-14-2021 13:03
01-14-2021 13:03
Best Answer01-14-2021 21:06
01-14-2021 21:06
Thanks, I had already tried all the relevant suggestions in that link. I think the problem (which I didn't see mentioned there) is that
I upgraded my computer's Mac OS to Big Sur (11.1), and it hasn't synced since then. I also contacted Fitbit Support, and their
suggestions didn't work, either. I think the Fitbit CHarge 2 just isn't compatible with Mac's new OS. Hopefully it will be at some point.
Best Answer01-15-2021 04:35
01-15-2021 04:35
01-15-2021 04:35
01-15-2021 04:35
The software for Mac has not been updated for 2+ years. No matter what the fitbit support says, there is nothing wrong with your tracker, its the outdated software that is the problem.
