11-06-2017
13:40
18:54
11-06-2017
13:40
18:54
I have a Sony Xperia XA1 and have downloaded the fitbit app but it is not syncing with the fitbit watch, what can i do? Is it not compatible?
11-06-2017 23:56
11-06-2017 23:56
It's not on the list of supported devices at www.fitbit.com/devices
However, this could mean either that it doesn't work with fitbit or just that it hasn't yet been tested. Hopefully someone with that phone will confirm either way.
How far through the setup are you getting before you hit a problem?
11-07-2017 00:21
11-07-2017 00:21
11-07-2017 00:25
11-07-2017 00:25
That's usually the point where incompatible phones hit a problem.
If yours is on the supported list then I would try restarting it using the following procedure:
12-26-2017 10:06
12-26-2017 10:06
I got a XA1 for my Christmas to replace my XA. On my XA I had a Flex2 and Charge 2 HR synced to my account. For some reason, perhaps being in the swimming pool too long on Christmas eve my Flex2 stopped syncing with the XA around 17.25 on same day. The Flex2 is supposed to be waterproof and set up for swimming but had already been replaced because of a battery issue.
On Christmas day I installed the fitbit app on my new XA1 and managed to sync my Charge 2 HR but was unable to sync my Flex2. This may be because it is not compatible with the XA1 or as a fault occurring the previous evening.
I have been in touch with Fitbit support but it looks like I will have to buy a different waterproof fitness tracker to be able to sync with the XA1.
12-26-2017 11:14
12-26-2017 11:14
Many thanks to the trouble shooters at Fitbit who have just sent me an email with a couple of ideas to get my Flex2 working again. After putting it on charge and pressing a small button on the bottom of the charger a few times it is now syncing perfectly with my XA1. At least now I know the Charge 2 HR and Flex2 are compatible with my phone.
Cheers again Fitbit tech support.
12-28-2017 20:31
12-28-2017 20:31
I have a Sony xperia XA 1 ultra and got a fitbit alta HR yesterday. The set up was made alot easier by this community btw, thanks. But also, on topic, the phone seems compatible as everything is set up on the app and running smoothly so far. I think perhaps some phones are compatible, but have not been tested and updated. I was quite frustrated at first when reading about fitbit being compatible with certain andriods only after spending so much on a device. But alls well that ends well right.
12-29-2017 00:35
12-29-2017 00:35
It's great to hear about new mobile phones and Fitbit products being compatible. The technology advances but not always at the same pace. I found that reading comments on the forum and getting helpful emails from Fitbit support department helped sort out the issue I had. Communication is a great thing 🙂
06-02-2018 10:21
06-02-2018 10:21
i have got to this stage but cannot find my watch
06-05-2018 09:22 - edited 06-05-2018 09:46
@sredder Welcome to the Fitbit Community! I hope you're doing well! Sorry to hear that your tracker isn't syncing with your phone. While your phone isn't listed as a compatible device it doesn't necessarily mean that you can't use it with your tracker. Please try these suggestions and then try to setup your tracker.
Let me know how it goes!
06-08-2018 06:51
06-08-2018 06:51
still no luck been back to the store who sold it to me , they was going to get rep to come into store . Today have a phone call from the store rep says my phone is not on the list which i have been saying all the time all i want to know will my watch work on my phone and will Android 8 system work with my charge2. I cannot be the only person with Android 8. Looks like i will have to return watch.
06-10-2018 09:05
06-10-2018 09:05
@sredder thank you for checking with the store. You still didn't mention if you tried the suggestions I linked in my previous post. There are other members that have been able to use different Sony phones like mentioned in this thread. Please try the suggestions I mentioned to see if this helps. Also the Fitbit app does work with many phones running Android 8.
I look forward to your reply!
07-09-2018 23:48
07-09-2018 23:48
my wife`s charge 2 does connect and works with her XA1 without any issues. all been done automatically without playing with phone (android) settings.
07-18-2018 08:25
07-18-2018 08:25
@BigBossLobo Welcome to the Fitbit Community! I hope you're doing well! Thank you so much for the feedback. Is great to know that your wife's phone is working fine with her Fitbit tracker. Any chance you can tell which OS version is the phone running?
07-18-2018 11:50
07-18-2018 11:50
Hi Alvaro, it is Andorid 8.0.0
07-19-2018 10:15
07-19-2018 10:15
@BigBossLobo thank you for the information and for taking the time to reply. Hopefully this may help other members who have the same phone.
I'll be around!
09-12-2019 14:12
09-12-2019 14:12
What settings are you using and does she get notifications on her xa1 as well as mine wont work on my xa1 thanks.
