03-06-2016
08:40
20:15
03-06-2016
08:40
20:15
Hi, The strap for my HR charge just came off, is there a service center In bangalore , India ?
if not how can I replace the strap ?
03-06-2016 18:50
03-06-2016 18:50
Welcome to the Fitbit Community @PrashanthC. It's great to have you here. I'm sorry to hear about your damage Charge HR wristband. Fitbit has a warehouse in Thane, Maharashtra. Please get in touch with Customer Support. They will let you know what can be done.
Hope to see you around more often. ![]()
Best Answer03-06-2016 23:26
03-06-2016 23:26
03-07-2016 12:20
03-07-2016 12:20
@PrashanthC You can call 000-800-100-4540, between the hours of 10am ~ 8pm IST. Here is the email to reach them directly: support-india@fitbit.com
Catch you later. ![]()
02-03-2017 03:35
02-03-2017 03:35
I tried reaching out the mentioned contact number several times but nobody bothers to pick the call.
Could you please help me to fix my fitbit. I've got the same strap problem with my chargeHR.
Best Answer06-07-2017 03:57
06-07-2017 03:57
There is no display on my Charge HR . There is a gap seen in the strap. Pls let me know whom to contact. Purchase date 23rd Feb 1016.
No reply from 0800 100 4540.
Best Answer06-14-2017 12:26
06-14-2017 12:26
Hello
my Fitbit HR strap is worn out and in a bad shape
where can I buy a replacement strap ? Is there a center in india ?
07-18-2017 03:06
07-18-2017 03:06
Same issue for me. Need to change the strap - as the strap is having bubbles and comes off.
Is it possible to fix a new wrap?
If yes, where can I buy and get it fixed?
08-10-2017 04:09
08-10-2017 04:09
12-23-2017 21:20
12-23-2017 21:20
I am also facing similar issue of no display and gap in strip. Any service center in Bangalore ?
Best Answer01-02-2018 00:13
01-02-2018 00:13
Hey I bought this Fastract Fit-bit watch from Amazon. In the initial days watch was working fine nowadays it automatically goes into night mode which is very irritating kindly let me noe how to overcome this issue
Best Answer11-11-2018 09:21
11-11-2018 09:21
Prashanth, did you find a solution to the problem? I am facing the same situation now, my strap portion is coming off the edge of the display.. wondering if there is a way to get this fixed..
Thanks
Shaheen
Best Answer11-11-2018 17:27 - edited 11-11-2018 17:33
Hi everybody, thanks for visiting the Fitbit Community.
@Shaheen_S There are no Fitbit stores available to fix Fitbit products, however in order to help you, I created a case with Customer Support. Please check out your inbox on the next days. They will let you know how to proceed as soon as possible.
If you have any question, please let me know.
Best Answer11-18-2018 22:02
11-18-2018 22:02
My Fitbit isn’t turning on can u help me with wat to do
Best Answer11-20-2018 13:34
11-20-2018 13:34
@Vijetha Welcome to the Fitbit Community.
I would recommend following our troubleshooting steps to resolve charging issues on this link. If this doesn't help, please let me know if you have a Fitbit Charge HR or a different Tracker.
Keep on stepping.
Best Answer12-28-2018 20:56
12-28-2018 20:56
I have Fitbit Charge 2.It was working all right till last month when I had to go out of station for a fortnight. It was not being charged while I was away. When I returned, I found that there was no green light coming from the back of the device. I tried to charge. It was not charging. I cannot use it any longer.
How can I get this fixed? I am in Bangalore, Karnataka, India. Can you help?
Thanks
Ram
Best Answer12-31-2018 17:37
12-31-2018 17:37
@Ramsub Welcome to the Fitbit Community.
If you haven't done it already, please be so kind to perform a restart to your Fitbit Charge HR by following these steps. If this doesn't work, please clean the charging contacts using the instructions in How do I clean my tracker?
If your Tracker starts charging again, please follow these steps:
- Turn the heart rate off (devices > heart rate) and sync
- If you had the heart rate on auto turn it on instead and sync
- Finally, turn the heart rate auto and sync
Hope this helps. Let me know how it goes.
Best Answer01-28-2019 21:55
01-28-2019 21:55
Hi,
The strap of my Fitbit charge HR 2 has come off and it doesn't stay fixed, no matter what I do. Where can I get it serviced in Bangalore?
Best Answer02-27-2019 03:00
02-27-2019 03:00
Hi,
I am in bangalore for 2 weeks and I forgot charger for my FITBIT Charge 2 back home in hyderabad. Can anyone help me out with the charger for 1 day.
Best Answer02-27-2019 23:47
02-27-2019 23:47
Hello Saurabh,
You could call their customer support at 000 800 100 4540.
They are generally prompt.
