01-08-2017
17:48
10:13
01-08-2017
17:48
10:13
Hi! I just got a Charge 2 (upgrading from a Charge HR, which I loved). Right now, when I hold the side button, it turns notifications on/off. I'd really like this to instead start the stop watch, like how it did on the HR. Is there any way to make it do that?
Thanks in advance!
~J
01-08-2017 18:06
01-08-2017 18:06
No, @jerfb, there isn't a way to change that. On the Charge HR if you pressed and held the side button, it started the Workout mode, not the stopwatch. The Charge 2 has a lot more options for the Exercise Modes, so if you press & release the side button multiple times it will toggle through to the first Exercise Mode, such as WALK or RUN. When you see that Exercise Mode, you can tap the screen to change to the desired exercise type, and then press & hold the side button to start tracking the exercise.
01-09-2017 10:10
01-09-2017 10:10
Feel free to add your suggestions to the 'Feature Requests' Sub Forum, where users can vote, add comments,.. if there's a certain interest then there's a chance the developers pick it up and it'll be developed.
Important to prevent duplicates Search if the idea already has been suggested and add your vote / comment! ![]()
Feature Suggestions
Click / Tap here to add new suggestion
Best Answer12-14-2019 06:34
12-14-2019 06:34
Mine goes to quick settings and I liked it when it went to my music controls can I change that ?
