Issues putting the Charge 3 wristband
One of the 2 buttons you press to release the watch bands jammed and while I can pry it back out when I try and re-install the bands it jams again and does not hold the band. Is there a fix for this issue?
5 REPLIES 5
Hey @CollinKan, welcome to the Community.
If you are having problems with your tracker wristband. I recommend taking a look at the help article How do I change the wristband on my Fitbit device? and follow the instructions provide there to put the wristband.
Let me know the outcome. Woman Happy
One side of my Charge 3 watch band will not release.  While on one side the button releases the other is jammed and will not release.  Please help!
I am having the same issue,  device still works, but out of warranty.  Trying not to buy a new device because of a band
Same issue here. Fitbit is out of warranty (Feb 2019), and I can't get one side of the band on.
In addition, the screen is mostly non-responsive... It's disposable!
I am having the same issue.  The latch/button on the fitbit device is jammed and won't hold the band.  The issue is with the fitbit and not the band.
