Lines across Charge 3 screen - tried everything
Hi
My display face started showing a couple of lines a week or so ago
Today its got much worse - lots of lines and I cant see the display.
Ive restarted, done a long restart, changed to other fitbit clock faces.
No joy
Can it be escalated to support please ?
11 REPLIES 11
very similar thing has happened to my Charge 3 - and it seems to be a common problem. Maybe a hardware issue?
@HelenWB @PeterTtttt Welcome to the Community.
Let me help you with your Charge 3 screens showing lines. @PeterTtttt you don't mention any troubleshoots so I suggest you restart your tracker by following these instructions.
@HelenWB thank you for troubleshooting this issue. Since the issue  persists I have created a ticket so our Support team can further assist you via email.
Let me know how it goes.
Alvaro | Community Moderator
Hi. Thanks. I've restarted the Fitbit after the 15sec hold while charging 4
times. Also change watch faces. Nothing has worked and screen still v
bright with lines. Please can you help. Regards Peter
@AlvaroFitbit I am having the same issues as Helen.  I also have tried changing the clock face, rebooting from the fit bit and the long restart to no avail.  What else can be done to fix this issue?
Hi
i have the same problem. I have done multiple restarts and changed the clock face but it still persists. Any advice ?
thanks
kate
@Swood2500 @Wardk It's great to see you in the Community!
Thank you @Swood2500 @Wardk @PeterTtttt for troubleshooting this issue confirming you follow the steps I described in my previous post. I have also created tickets for all of you. You will get an email from our Support team.
Keep me posted.
I’ve posted my issue on other sites. I have exactly the same issue. I’ve changed the clock face - no change. I’ve tried the restart but that made no difference either. Please could you add me to the support ticket. Thank you
HiFitbit support are sending me a new tracker as mine is still within the 12 month warranty. HelenSent from my Samsung Galaxy smartphone.
Thank you. I did receive an email with instructions for a long restart and to update the app. I have done both but still have no success. The lines still appear and now it isn’t tracking my sleep. Do you have further advice?
Thank you
kate
HiI contacted Fitbit support and I'm being sent a replacement. It sounds as if you've tried everything else - its a hardware issue for sure. HelenSent from my Samsung Galaxy smartphone.
Im having the same problem but mine is out of warranty now is there anything can be done?
