06-11-2023 11:46
06-11-2023 11:46
Folks, like many of you my Charge 4's strap connector has finally broken off the tracker. The device still works well & has good battery life so I'd prefer not to have to get a new one just yet.
In looking for options, I saw a youtube video featuring a "one piece" strap in which the tracker is placed - it has a soft frame that stretches around the tracker & presumably does not require the end pieces that hold a the normal straps.
Sadly I cannot seem to find it shopping online. Anyone had any luck with a particular replacement band to hold the tracker? Thanks for any help.
06-25-2023 17:50
06-25-2023 17:50
Well after 2 weeks with this one from Amazon, I've decided it's a viable solution. The strap is comfortable & allows the device to work as per normal. Having the side covered does not impede use of the button at all. The device is held snugly & does not move around, even though the connector piece on one end is completely broken off. Would recommend as a cheap solution if your device is working but can't connect to the standard straps any longer.
Best Answer06-11-2023 14:18
06-11-2023 14:18
@jjreason Is this one similar to the one in the video? Will it work for you?
Laurie | Maryland
Best Answer06-11-2023 14:29
06-11-2023 14:29
Looks like it might. Thank you for the reply. Anyone able to advise whether or not the one linked above (or any others) will work?
06-25-2023 17:50
06-25-2023 17:50
