06-10-2020
04:55
11:33
06-10-2020
04:55
11:33
This just started to happen this week. My steps started going up when I open app then goes down after auto synch.
06-10-2020 05:01
06-10-2020 05:01
Same. Just started happening Monday
06-10-2020 08:12
06-10-2020 08:12
same. Also started Monday. Very frustrating.
06-10-2020 08:30
06-10-2020 08:30
Mine also started Monday. I called in to their help line.
Was told they are aware of this issue.
It has the highest level of support possible - it is affecting a lot of devices.
Have not heard if they have fixed it.
I turned my bluetooth off to not lose steps.
06-10-2020 08:43
06-10-2020 08:43
Same here! Keeps going back to zero. Lost several thousand steps today
06-10-2020 08:44
06-10-2020 08:44
I didn’t think of that- will turn off Bluetooth as well. Did that help save your steps????
Best Answer06-10-2020 08:56
06-10-2020 08:56
I have uninstalled the app for now but turning off bluetooth will work. If you reboot (not reset) device it will show correct steps again and I'm manually recording them for now.
Swipe to settings menu on fitbit, scroll up to reboot and select ☑
Best Answer06-10-2020 08:59
06-10-2020 08:59
Mine happened Monday too!
Best Answer06-10-2020 09:22
06-10-2020 09:22
Frustrating as hell.
I started a 70 minute treadmill walk and the Fitbit showed 938 steps. Finished with a Fitbit total of 1036. WTF?! 98 steps in 70 minutes! I am slow but not THAT slow. Tracking it provided an actual count of 7852 steps plus the beginning count of 938 which would equal a total of 8790. Ugh.
Best Answer06-10-2020 09:57
06-10-2020 09:57
Weird. Yes mine too started Monday.
06-10-2020 10:11
06-10-2020 10:11
Best Answer06-10-2020 10:18
06-10-2020 10:18
I think it’s a problem when having a secondary app looking Stephs from Fitbit.
Best Answer06-10-2020 11:42
06-10-2020 11:42
Here is how mine happens. Exercise - fitbit keeps good track of steps.
Go to sync with phone. It initially shows correct steps.
When sync is complete it shows less steps.
There was an App update last night.
Has anyone tried it?
Afraid to lose my steps.
Best Answer06-10-2020 12:54 - last edited on 06-10-2020 17:28 by LiliyaFitbit
Did yours start this week also? Mine doing the same thing-worked fine until this week. I get steps, synced. Lost....
Best Answer06-10-2020 12:56
06-10-2020 12:56
Monday - hit 17000 steps - synced again around 2 or 3 pm and it went to 3400
06-10-2020 13:21
06-10-2020 13:21
Yes.. started Monday!
Best Answer06-10-2020 13:22
06-10-2020 13:22
yes but if you reboot the charge 3 it shows correct steps again. Its when it syncs to app it loses the steps.
Best Answer06-10-2020 13:25 - last edited on 06-10-2020 17:27 by LiliyaFitbit
I just finished with a live chat. Says it is their issue. And supposedly they are working on it. The rep said I had over 10000 today but the device and app show 5200
06-10-2020 13:33
06-10-2020 13:33
Same! Mine also began happening Monday
Best Answer06-10-2020 13:54
06-10-2020 13:54
Thanks for the update Amy.
