Lost my Charge 2 but found it
I lost my charge 2. Took all day but I found it.  I used LightBluexplorer app for my iPhone.  It neglects to tell you to disconnect Bluetooth for your charge2 or it won’t work.  Took all day to to find it because I had to figure this out myself.  Hope this saves someone else some time.  Good luck!
Moderator edit: Subject for clarity and format
3 REPLIES 3
So happy you found it! Woot!
Community Council Member
Wendy | CA | Moto G6 Android
Hi frazelz,
Can you please explain what you meant by the fourth sentence about disconnecting?
I didn't know you could "find" the Charge 2 by somehow getting your phone to buzz the Charge 2 (but Im using Android version).
Cheers
Hi @frazelz, I hope you are doin' fine! Sounds great that you found your Charge 2! Thanks for sharing the tips that worked for you. I'm pretty sure they will help out other users.
@Funsky, welcome aboard! I suggest you to take a look at the instructions in this help article: What should I do if I lose my Fitbit device? And I hope you find it!
@WendyB, thanks for stopping by!
I'll be around!
Heydy | Community Moderator, Fitbit
