11-20-2021
13:03
17:29
AndreaFitbit
11-20-2021
13:03
17:29
AndreaFitbit
My Mac book will not let me sync my charge fit bit. I have tried everything including uninstalling app and re installing it. very frustrated Any help out there
Moderator edit: format.
11-28-2021 11:14 - edited 11-28-2021 11:16
Hello @Rormag and welcome to the Help forum. Can you please provide a little more information about the Charge model you use? If you have a newer model Charge (3,4,5), you must use a compatible phone or tablet. You use some software called Fitbit Connect with a Mac. There are two compatibility issues. Newer Fitbits just aren't compatible with Fitbit Connect. Older model trackers that can use Fitbit Connect have a different problem with Macs. There are Bluetooth issues with newer Mac OS. Anything newer than Mojave (I think) has this Bluetooth incompatibility.
I looked at your profile and I can see that you are a new user. But you posted in a forum for older model trackers and some clarification will help. Both the Charge and the Charge HR are legacy devices. They can be problematic, period.
Laurie | Maryland
