12-16-2017
		06:05
		18:54
		12-16-2017
		06:05
		18:54
I have my main goal set as Steps, but the display shows Active Minutes. I can successfully change my main goal to anything else, and it syncs and displays, but when I set it to Steps, I always get Active Minutes.
I have searched the forum and have done things that were posted by other moderators, but I still get Active Minutes as my goal.   I have uninstalled the FitBit app from all other devices, I've restarted my Charge 2, and it still goes back to Active Minutes.
Please help.
12-16-2017 09:48
12-16-2017 09:48
Yep, I did that - it still did not work.
However, I do think I found the problem. While I had "Steps" as my Main Goal, I discovered that on the web there's a setting called Tap Display. Tap Display had Active Minutes as the top display, and Steps as the second one. I put Steps at the top, and voila! it worked.
 Best Answer12-16-2017 09:31 - edited 12-16-2017 09:32
Have you tried setting it through the web? Fitbit.com - the setting gear top right - blaze
Then sync the tracker.
 Best Answer12-16-2017 09:48
12-16-2017 09:48
 Best Answer07-10-2019 10:41
07-10-2019 10:41
Where is this ‘Tap Display’ located? I’ve re-set from both iPhone and computer site and re-synced several times — but I still can’t get a display for steps.
 Best Answer07-10-2019 10:49
07-10-2019 10:49
Finally got my steps displayed — but I think it was simply a lucky set of frustrated button pushing.
