09-16-2016
18:41
10:26
09-16-2016
18:41
10:26
Please make a X-small band for little adults and teens. Would be great!
12-18-2019 07:59
12-18-2019 07:59
My 17 year old daughter has a very small wrist. She can't wear her fitbit to dance practice because it won't stay put. Why not make an XS band?
12-18-2019 13:07
12-18-2019 13:07
Hi, @alliecarpenter, which Fitbit does your daughter have? For most of the earlier Fitbits the real problem is not the band but the tracker itself, which was often wider than a small wrist, so however small the band, there was always a gap.
The Inspire and Inspire HR will fit a tiny wrist, especially with some of the custom accessory bands (I love the stainless steel mesh in rose gold). The watch faces on the new Versa models are fairly big, but still can sit flat on most wrists, even very small ones.
Basically, the problem was really with the tracker, but now that technology has moved on, an amazing amount can be fitted into a very tiny package.
Having said that, if yur daughter has an Alta, or an Alta HR, she can buy the kids’ Ace band in extra small, and it will fit and be compatible.
Best Answer12-19-2019 05:50
12-19-2019 05:50
Thanks so much, Julia!
That's really helpful information.Yes, she uses an alta hr that's a couple years old.
After searching quite a bit, I didn't find the band you're talking about (I saw this post after my search), but I found a velcro fastener. Yes, my daughter loves the stainless steel wrap band, but it flies off her hand in dance practice. I hope this velcro one will work the same way, but stay on.
Thanks again for your help!!!
Best Answer07-23-2020 05:57
07-23-2020 05:57
I'm 47 years old and 5'7" and nearly 145 pounds so defs not underweight.....my wrist is 4.5".....I need an x-small band. It's not just kids out there with tiny wrists 😞
03-18-2023 15:14 - edited 03-18-2023 15:15
PLEASE PLEASE MAKE AN X-SMALL BAND!! I am 73 years old and have never been able to wear a watch properly because all the bands are way too large for me and slip off my hand. I love the Charge 5 but can’t wear it appropriately because the small is too large 😢 Manufactures are considerate of women with large wrists but no one thinks about making a band for us tiny petite women with wrists the size of a 10-year old!
