Manual entry for nap lists 0 minutes sleep
Whenever I Manually enter a 15 - 20 minute nap my Fitbit calculates 0 minutes sleep.  I have tried adjusting the start time or end time to no avail
2 REPLIES 2
Hi, @sfc335! Honestly, it probably means that if you're taking that short of a nap, your heart rate is probably not dropping that much and you're not settling into the sleep stages. You're probably restless enough that it's not counting it as sleep. I'm not sure there's anything you can do to adjust it, it's just the algorithm.
MakMak | Community Council
Prior to one of the recent upgrades, I could enter a nap and because it was a short amount of time, there were no sleep stages and it just accepted the amount of time I d entered.  Now I enter 15 minutes and Fitbit says 0 minutes sleep. How can I manually capture nap time?
