05-14-2021
12:38
05:07
WilsonFitbit
05-14-2021
12:38
05:07
WilsonFitbit
When I went in a bike ride today my Fitbit charge 3 and the app showed the correct location for my start and ending point of my ride but the miles calculated was half the distance and the calories burned was half. Coming back it had the right distance and calories but that map stopped at shorter that tge half way point.
05-15-2021 05:12 - edited 05-15-2021 05:12
Hello @Denisebmb. Welcome to the community forums!
Thank you for the detailed information and for the screenshot. The connected GPS feature on Fitbit Charge 3 works with the GPS sensors in your nearby phone. I recommend turning off Wi-Fi on your phone when using connected GPS to improve the experience.
When you choose a GPS exercise, your device vibrates when your phone finds a GPS signal. If your phone doesn't find a signal immediately, keep in mind that environmental factors including tall buildings, dense forest, steep hills, and even thick cloud cover can interfere with your phone’s ability to connect to GPS satellites.
For best results, wait for your phone to find the signal before you start your workout. However, if you don't want to wait you can start your workout and GPS tracking begins when your phone finds a signal. Also, note that your device uses your step count to calculate distance until it finds a GPS signal. In this scenario, your total distance calculated for the workout may be slightly less accurate than if GPS data were available for the entire duration. For more information, see How do I use GPS on my Fitbit device?
Requirements and troubleshooting for best results:
Regarding active minutes, I recommend visiting this link for more information: What are Active Zone Minutes or active minutes on my Fitbit device?
Hope this helps.
