03-27-2019
07:31
16:45
03-27-2019
07:31
16:45
I need to make changes by opening the GEAR Icon but it does not appear in DASHBOARD...I do know that it's supposed to be there and you closed the other Post about it...If you can't give an answer I have a Fitbit Charge 2 that can be had for pennies...
03-27-2019 08:16
03-27-2019 08:16
The gear icon on the web dashboard at www.fitbit.com is at the top right as shown below:
Are you perhaps using the app instead? What setting are you trying to change?
03-27-2019 10:26
03-27-2019 10:26
Best Answer03-27-2019 10:28
03-27-2019 10:28
My dashboard doesn't look like that and why did they make it so I can't cut and paste a picture in so you can see...
Best Answer03-27-2019 10:55
03-27-2019 10:55
You can include a picture in your post using the "photos" button:
Would your dashboard happen to look more like this?
03-27-2019 11:31
03-27-2019 11:31
Yeah I went to photos and it's not helpful at all won't just let me cut and paste, why make it easy...oh and by the way I am using the App which I found out doesn't have the GEAR icon...only the The online application does...and it doesn't matter you have to change it in the online version because when you change it with the PC app the changes do not stay...so I ask myself why use the PC app?so if someone say they don't have a gear icon...they are using the PC application...
Best Answer03-27-2019 20:42 - edited 03-28-2019 22:00
You need to save the photo to your computer and then Upload like stated above. You cant copy and paste to a thread. It will not work
It also would of been helpful from the beginning that you were using the app. We cant guess how you are accessing the data
Wendy | CA | Moto G6 Android
04-02-2019 02:04
04-02-2019 02:04
@Wagney let's take a step back. You have asked about your Dashboard. Fitbit has several versions of the dashboard.
The one version may be found at Fitbit.con, this is the version we think you are referring to.
Then we also have the Fitbit app version, with 3 different Fitbit apps for the 4 different phones and the windows 10 Fitbit app for the PC.
Your question was found on the Charge board mentioning the Charge 2 but the question is about the Fitbit app or Fitbit.com.
On Fitbit.com the setting gear is found in the top right.
In the Fitbit app on an Android phone we do not have a setting gear, but what some call an index card..
The real question of what do you want type of setting do you want to change would help us out. Do you want to change a setting on your Fitbit device, your Fitbit account or your Fitbit community account?
04-02-2019 12:25
04-02-2019 12:25
