My Charge 2 died yesterday.
It died all of a sudden. I put the Charge 2 on the charger and pressed the start button for 12 seconds but still nothing happened. What else should I do?
2 REPLIES 2
@selah12, welcome to the Fitbit Community! I hope you're doing well!
Let me help you with your unresponsive Charge 2 and thank you for troubleshooting this issue. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
Let me know how it goes.
Alvaro | Community Moderator
Hello AlvaroFitBit,
Thanks for your response regarding my Charge 2.  I tried cleaning the contacts with alcohol and charging it overnight. Alas,  still nothing.  I have tried other methods as well. Are there any other suggestions. I've only had this one for 19 months.
