07-17-2017
12:39
11:17
AndreaFitbit
07-17-2017
12:39
11:17
AndreaFitbit
My fitbit time zone is wrong i have reset several times ,removed and reset up, set to deliberately wrong time zone manually but time remains 8 hrs behind?
07-18-2017 07:08 - edited 07-18-2017 07:09
It's nice to see you around the forums @deb17, hope you're doing good! Thank you for all the troubleshooting you've tried to fix the time zone issue, nice way to go.
Let's try something different, all right? Here we go... If you use a mobile device to sync, check if you have the automatic time zone enabled in the settings of the phone, if not, I suggest turning that option on so the Fitbit App can pick up the information from the Internet and set the time in an automatic way.
Additionally, check if the automatic time zone is also set in your Fitbit App. Here are the steps:
1. Go to the Settings in your phone and tap on General:
2. Select the Date & Time option and verify that the Automatic time is on:
3. Go to the Fitbit app and tap on Account, then scroll down and select Advance Settings, there you'll find the option to set the Automatic time:
If that doesn't work, I'd recommend trying to update the time zone online by going to https://www.fitbit.com/settings/profile. Don't forget to sync after you change, maybe this helps to update the time on your app and tracker.
Give this a go and let me know the outcome!
07-20-2017 06:54
07-20-2017 06:54
I went thru the settings and found the location button turned off. Reset it to on and then synced HR with phone app and now the time is correct. Thank you
07-20-2017 07:59
07-20-2017 07:59
Music to my ears @Marshallmr. I'm so happy to hear that you're back on track my friend.
Hope to see you participating in the Community more often since I think it would be awesome for you to explore our Community. You can go ahead and log to any of the topics that might be of your interest in our Discussion boards. Feel free to comment and contribute with your knowledge and experience.
Enjoy the rest of your day!
08-10-2017 12:01
08-10-2017 12:01
My fibit Charge 2 has been losing minutes for the last 3 hours. I keep syncing to the app, have Auto detect time zone on,(but it keeps turning itself off in the app). Running 22.22.54.6. What is up with this? Am I the only one?
08-11-2017 05:18 - edited 10-08-2024 07:58
Thanks for stopping by @denise94404! Hmmm... this is weird my friend. I'd recommend doing the following:
Once you've done that, please follow the steps I've shared in my above post.
Let me know if this finally works!
10-05-2017 00:00
10-05-2017 00:00
I turned the automatic settings on and off a couple of times and synced it a couple of times and then i just changed back to the right time, go figure. husband not happy i woke him up an hour early though LOL
10-05-2017 06:37 - edited 10-05-2017 06:38
Hey there @Chrissodotcom! Did the steps you take made the trick? but he didn't get mad, right? hahaha
04-06-2019 00:45
04-06-2019 00:45
I have tried everything suggested but my Charge 3 still runs permanently 1 minute late. Very irritating when alarms and reminders activate after I have reached for my phone to check them out.
01-12-2020 21:53
01-12-2020 21:53
Hi I am having the same issue with my ionic. Over the past few days I have tried all the suggested methods of correcting this so far as to remove the watch from my device and re add and now finally my ionic won’t even connect at all.
