06-11-2017 08:04 - last edited on 09-09-2020 09:49 by MatthewFitbit
At least twice a day I have to uninstall then reinstall my fitbit app because it has stopped syncing. Does anyone know why and how I can rectify the problem? Thanks
06-12-2017 09:07
06-12-2017 09:07
06-12-2017 09:03
06-12-2017 09:03
Welcome to the Forums @Mitsykitsy! This is definitely pretty weird. You shouldn't be uninstalling and reinstalling the app on your phone to sync your Charge 2. Let me ask you something, are you getting some type of error while trying to sync? In the meantime, please try the following to fix syncing issues:
- Restart your Charge 2
- Follow these tips to fix syncing issues with Android devices
Let me know how it goes!
06-12-2017 09:07
06-12-2017 09:07
06-12-2017 09:08
06-12-2017 09:08
Thanks, I will
06-13-2017 06:11
06-13-2017 06:11
Thanks for getting back to me @Mitsykitsy! Yes, give it a try and let me know if that works! I will appreciate the update. 😉
Have a nice day!
10-11-2017 11:10
10-11-2017 11:10
I've been following this path for the past 3 weeks in a row, and my tracker will sync for a couple of days, and then stop again. 3 weeks in a row! This is frustrating 😞
10-13-2017 09:27
10-13-2017 09:27
Has your sync problem been fixed. I'm having the same problems with my charge 2 last update 2days ago keep turning Bluetooth off restarting but nothing just sync when it wants too days later.
10-13-2017 15:39
10-13-2017 15:39
10-13-2017 15:43
10-13-2017 15:43
Hi I rang customer support went through some trouble shooting problems with them it's sorted out for now. Give them a call
10-13-2017 17:05
10-13-2017 17:05
I am having the same issues - the bar on top goes about 1/3 across the iPhone and then disconnects. Frustrating!
10-24-2017 15:11
10-24-2017 15:11
My flex2 isn’t syncing properly
10-27-2017 20:39
10-27-2017 20:39
Worked for a few days, back to not syncing. Don't know why it says that issue was solved, it hasn't been solved!
10-28-2017 18:47
10-28-2017 18:47
Hello,
I have the same problem. I've read this thread and but the problem has not been resolved. Turning a device on and off is not a solution. Has Fit Bit properly addressed the issue yet?
Please share!
Thank you.
- m
10-29-2017 01:45
10-29-2017 01:45
10-29-2017 04:18
10-29-2017 04:18
My Charge 2 says I have not synced lately. How do I do that?
10-29-2017 04:41
10-29-2017 04:41
Sorry don’t know x
12-05-2017 01:29
12-05-2017 01:29
Have u worked out how to sync it? Mine did it once and won't do it again
12-05-2017 07:58
12-05-2017 07:58
05-19-2018 07:47
05-19-2018 07:47
Hi, I have the new Fitbit versa. It sanc for a few days too. Now nothing for the third day. When I pull down to sinc it says (looking) this is very annoying! Did yours get fixed? I even tried to reinstall the Fitbit app.:(((
05-19-2018 07:55
05-19-2018 07:55
I’m having same issue with my new versa. It did sinc for two days then stopped! This is extremely annoying. It shows up on my fitbit(steps) that’s it. Help!!!
