10-28-2017
07:33
09:26
10-28-2017
07:33
09:26
Help! My Fitbit it is dead apart from the Fitbit logo and the number 22.55.02 . Have tried to restart and it’s been charging but there is no life in it. Please help
10-31-2017 09:10
10-31-2017 09:10
Hey @San01, welcome to the forums! Thanks for trying to restart your Charge 2. Beside that, I'd like you to wait until the battery of your Fitbit drain out and the screen is completely dead. Then please plug your tracker into the charging cable, perform a restart and wait util it is totally charged. If still stuck after that, let me know! 😉
Have a nice day!
11-12-2017 17:05
11-12-2017 17:05
My Fitbit Charge 2 only displays the 22.55.02 along with the logo. Please help
11-13-2017 05:32
11-13-2017 05:32
I had the same problem and emailed Fitbit direct. Eventually they had to send me a new tracker. All sorted within a couple of days and received my new tracker within 5 days.
11-13-2017 08:05
11-13-2017 08:05
Hey @KWeary, welcome to the Community! If your Charge seems to be stuck with the Firmware version and the Fitbit logo, and not responding to anything else, I suggest you to restart it and if that doesn't work, try to set it up as a new device and let me know how it goes!
@San01, thanks for that update. I know that our Customer Support is the best of the best so sound pretty cool that they have sent you a new tracker as a replacement. 🙂
Have a nice day, guys!
11-12-2018 09:48
11-12-2018 09:48
My charge 2 is stuck on 22.55.02. I let it drain to zero and the charged it and restarted and it's still stuck on the same thing, 22.55.02
Please help
Thank you
11-12-2018 11:18
11-12-2018 11:18
Hey @LennyMonroe, let me give you a warm welcome to the Community! Thanks for trying some tips to try to fix this issue with your Charge 2 that seems to be stuck. Beside of those steps, I'd like you to set it up as a new device by following these instructions:
Let me know how it goes!
11-14-2018 09:35
11-14-2018 09:35
Hello - I am having an identical problem which started this past week.
When I perform reset I end up with 22 55 02 on my Charge 2 screen. I fail to pair with my Windows 10 laptop. I have uninstalled and reinstalled the Windows 10 Fitbit app without any change. I have turned bluetooth on and off numerous times with all other bluetooth devices working fine. I removed my original Charge 2 from my account and attempted to Setup a New Device but the screen of my Fitbit never lit up (either w/out and with the charge cable) and the Fitbit app failed to make any connection.
What has changed? How do I fix this?
11-14-2018 10:00
11-14-2018 10:00
Hey @Malcolmian, let me give you a warm welcome to the Community! I appreciate you have taken the time to try to fix this issue with your Charge 2 that seems to be stuck. I'd like you to also try to set up your Charge 2 and update it's firmware but this time using a compatible mobile device.
11-14-2018 19:58
11-14-2018 19:58
OK. I have tried to set up my Charge 2 as a new device on both my wife's MacBook Pro and an iPhone. The setup routine is getting hung up because it can not pair with my Charge 2. On my Windows 10 laptop bluetooth can "see" the Charge 2 but fails repeatedly to "pair". On the MacBook Pro and the iPhone, bluetooth does not even "discover" the Charge 2, even after numerous resets of the Charge 2. I am continually frustrated by the quality of the FitBit product and the absence of a simple and common solution to what appears to be a prevalent problem.
02-06-2019 07:55
02-06-2019 07:55
I'm so disappointed with mine, same issue as yours, just dead won't charge won't connect and won't re-set
02-06-2019 08:27
02-06-2019 08:27
Hi
i has to contact Fitbit online and they sent me a new one in the post
02-06-2019 08:35
02-06-2019 08:35
03-14-2019 17:03
03-14-2019 17:03
i have the same problem
03-14-2019 17:45
03-14-2019 17:45
Yup. I have the same issue. I have tried everything that is here and it will not work. Please help.
03-15-2019 01:36
03-15-2019 01:36
03-25-2019 09:38
03-25-2019 09:38
Yep - similar over here too....... Ergh
04-01-2019 22:32
04-01-2019 22:32
I give up... done everything... bye bye fitbit… been with you guys since 2015
06-17-2019 10:32
06-17-2019 10:32
I have had the same problem, where it was stuck on the fitbit logo/full charged battery symbol (even though I know the battery isn't charged). I tried resetting, and that fixed the problem for the first couple times, but then it would die randomly (black screen, no display) and eventually the reset trick stopped working and will only display the fitbit logo/full charged battery symbol when plugged in.
Now, the reset doesn't do anything, it just goes back to the original screen. Unfortunately, my fitbit is out of warranty, so I don't think a replacement will be covered anymore... Bummer...
06-25-2019 16:06
06-25-2019 16:06
I'm having the same issue. No help from Fitbit- basically said I was SOL. Tried resetting, tried reinstalling, tried restarting, tried changing bluetooth, etc. etc. no luck.
