05-13-2017
16:39
08:30
AndreaFitbit
05-13-2017
16:39
08:30
AndreaFitbit
My fitbit was fine then it just stopped. No green light nothing.
05-17-2017
07:32
14:07
05-17-2017
07:32
14:07
@ladylibra1010 I hope you're doing well! Have you tried charging you tracker? Start by cleaning the tracker's contacts with a toothpick or toothbrush and then use cotton with rubbing alcohol to finish the process (clean the charging cable contacts too with this). After this try charging your tracker and try restarting it by doing the following:
If this continues then you can try contacting support like @WendyB suggested.
Let me know how it goes!
05-13-2017 22:03
05-13-2017 22:03
Welcome to the forums!
Please Contact Support
http://help.fitbit.com/?cu=1
Wendy | CA | Moto G6 Android
05-17-2017
07:32
14:07
05-17-2017
07:32
14:07
02-27-2019 19:22
02-27-2019 19:22
My Fitbit was fine and must have died sometime during the day today. Now nothing!!! No light and won’t charge. I tried cleaning ports, plugged into computer and hit reset button but NOTHING happened!!!! What do I do???
03-22-2019
20:19
14:06
03-22-2019
20:19
14:06
@Morris1321 thank you for the update and sorry for the late reply. Since the issue persist after trying the suggestions the best thing to do is letting our Support team know so they can help you. I noticed that you already have a ticket with them so I wanted to know if they were able to solve the issue.
I look forward to your reply.
Best Answer05-08-2019 22:47
05-08-2019 22:47
My fitbit died. I cleaned it with alcohol and changed the sport, but it didn't work. Help please!!
08-17-2019 17:28 - edited 08-17-2019 17:43
Clean every bit with alcohol. It worked for me!
- nevemind, died again.
Best Answer03-12-2020 09:54
03-12-2020 09:54
This the Second verse I have had that did this ,this one only a month old. Your solution didn't work. I'm pretty well done with fitbit. Any have the true fix
03-17-2020 01:47
03-17-2020 01:47
After 19 months my fitbit died, was a good watch up until then My mistake was forgetting to remove it before i went for a swim. when i got back it rebooted then died and has not worked since. tried all the steps - nothing, tried to charge it just gets hot and does zip.
Decided to throw it away and never purchase another fitbit, I was dumb enough to believe i would get an electronic watch that lasts at least 3 years. This is my second fitbit device, first one lasted 14 months but failed as i dropped it so understandable. Switching back to my Omega and using my iPhone for an alarm clock.
Best Answer03-25-2020 01:55
03-25-2020 01:55
My fitbit started showing the wrong heartbeat. I took it off and left it overnight, tried this morning and is not working. It will not charge. Many thanks for any help.
05-02-2020 06:59
05-02-2020 06:59
When I hold the button for 10-12 sexonds, it keeps buzzing non stop. Nothing shows on the screen.
Best Answer05-28-2020 06:32
05-28-2020 06:32
My husband and I both have fitbits. His was only 6 months old and mine 5. His started acting funny losing time and no sensor lights and then it just died. No vibration, no lights, nothing. Then my Fitbit just died with the same symptoms black screen, no sensors, no vibration, nothing. This happened within two days of each other. So either one of us has a working fitbit. Sorry about the long rant, but coincidence much?
Best Answer06-09-2020 20:51
06-09-2020 20:51
My battery was at 75% when I synced this evening and now it's totally dead. It won't charge even after cleaning, and anyway, that shouldn't be a dead battery. At 75%, I usually have several more days before the battery gets low and I need to charge. 😡
Best Answer07-06-2020 14:55
07-06-2020 14:55
My Fit Bit Versa is less than 2 years old. Yesterday I put it in the charging cradle (at 47% charge) and after a few minute it died.....won't charge, won't reset (press Back and lower Right button). Cleaned contacts with alcohol. My husband's Fit Bit charges fine in the SAME charger. Waited online for 20 minutes for a Live Chat with Fit Bit support......they gave me all the same things to try that I already tried.....nothing. Bye Bye Fit Bit...hello Apple watch.
11:59
14:06
07-16-2020
11:59
14:06
@SunsetRunner734 Welcome to the Community.
Let me help you with your Versa not working and thank you for reaching out to our Support team. I reached out to them to see what happened and they informed me that your device was outside the warranty period so they couldn't provide a replacement for your device. You can check the warranty here.
Let me know how it goes.
Best Answer09-07-2020 05:38 - edited 09-07-2020 05:50
My Fitbit just died. It had been charged , cleaned, was not old, and my second try at a Fitbit. I too am done with this product which has resulted in replacement after replacement because they do not last more then 2 years before dying unexpectedly or having problems needed in a replacement.
09-07-2020 06:54
09-07-2020 06:54
09-08-2020 16:34
09-08-2020 16:34
This has happened to mine too, all out of the blue. I had 47% battery and it just did after a 2 he walk. Now it won’t charge. Everything has been cleaned ... nothing
Best Answer01-19-2022 00:10
01-19-2022 00:10
Yes mine has died too. Appears to charge but won’t reboot. Screen black. A shame because I have integrated Fitbit into my life and now I feel a bit lost. Somehow I doubt that buying another Fitbit is a smart move if this is what happens after they reach a certain age.
01-20-2022
11:05
14:06
01-20-2022
11:05
14:06
Welcome to the Fitbit Community, @Blanny. Thank you for mentioning what´s happening to your Charge 2.
I appreciate your comments regarding Fitbits life and the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Keep on visiting the forums.
