10-11-2018
07:11
06:11
JuanJoFitbit
10-11-2018
07:11
06:11
JuanJoFitbit
My clock face is showing 03.10 when its actually 15.10. Doesnt seem to be anywhere to either change to 24 hour clock or at least get rid of the 0. Does anyone know how to do it?
And agree with other posts - we need date!
10-11-2018 07:29 - edited 10-11-2018 07:30
You can change to the 24 hour clock but not in the app on your phone. Go to the website dashboard instead and select the gear wheel icon in the top right and select Settings. Scroll down to Advanced Settings and select Clock Display Time. You can then change to a 24 hour clock. Let us know how you go
Lol beaten by @wmchapman. At least we agree!
Helen | Western Australia
10-11-2018 07:25
10-11-2018 07:25
On a PC log into your fitbit.com account
Click the grey'd gear in the upper right corner (profile)
Scroll up to "Clock Display Time", click the drop arrow to make 12 hour
(double check the Timezone setting as well while you are there)
Remember to hit submit at the bottom of the page.
Next time your tracker syncs should be as you want 😉
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
10-07-2019 17:05
10-07-2019 17:05
I would like to use a 12 hour clock that shows AM and PM do not want a 24 clock. If I use 24 clock I get 1700 hours at 5PM if I switch to 12 hour clock at 5PM I get 0500
12-04-2019 21:26
12-04-2019 21:26
That is not the answer to the question, let alone the "best" answer. The problem for which a solution is needed (by me as well) is not that the clock is showing the 24-hour clock or not, but that the clock is 12 hours ahead or behind. Has anyone else had this issue with the Versa 2?
03-09-2020 15:02
03-09-2020 15:02
I have the same issue. My Versa 2 has recently started recording my sleep and exercise 12 hours behind when it happened. The clock face time is correct as is the time zone.
04-07-2020 09:24 - edited 04-07-2020 09:26
My moms Fitbit versa 2 is 12 hours behind too and none of the “time zone” fixes worked. Anyone find a solution ? And she can’t read military time that “best” solution doesn’t work for anyone.
02-07-2021 21:18
02-07-2021 21:18
Did you ever figure out the date issue? My Versa 2 is 12 hours ahead.
02-04-2022 13:19
02-04-2022 13:19
Has anyone figured this out yet? It's currently 221 my Fitbit says 0221
Best Answer03-16-2023 14:22
03-16-2023 14:22
Yes but my versa 2 is all of a sudden 33min behind. Not even an even number. It's yrs old but everything else is fine
Best Answer03-16-2023 14:25
03-16-2023 14:25
Yes but my Versa 2 is 33 min behind. Not even an even number. It's yrs old but everything else is fine. Charges the same. Still syncing.
