08-05-2022
04:11
16:37
AndreaFitbit
08-05-2022
04:11
16:37
AndreaFitbit
For a few months now I can only see my screen when inside. I have it set on Brightness but it does not show up when outside and is just dark. This is the 3rd time this has happened to me when my fit bit reaches about 18 months old. Please can you help me.
Moderator edit: updated subject for clarity and label.
08-05-2022 04:19
08-05-2022 04:19
Hello @K1K1Pil and welcome to the Community. What model Fitbit do you use? Your post can get moved to the correct device forum where you might get more help.
Laurie | Maryland
Best Answer08-05-2022 23:02
08-05-2022 23:02
Best Answer08-06-2022 10:50
08-06-2022 10:50
Did you ever get this solved mine seems to be doing the same thing
08-06-2022 16:39
08-06-2022 16:39
Welcome to the Fitbit Community, @K1K1Pil and @rwalker82. Thank you for your assistance @LZeeW. I'm sorry to hear about your Charge 3 screen.
Please confirm that you have tried restarting your tracker with the instructions of: How do I restart my Fitbit device?
Keep on visiting the forums.
Best Answer08-08-2022 09:47
08-08-2022 09:47
Same here. I have already restarted the device without changes. I see this is an issue that a bunch of us are suffering. It started some time ago and since sometimes I can see the display totally lighted, I can tell it is not a matter of the light.
Thanks,
08-08-2022 14:04
08-08-2022 14:04
Same here. Did anyone ever get a reply or fix for this? It seems to be getting worse.
08-08-2022 14:06
08-08-2022 14:06
08-09-2022 06:53
08-09-2022 06:53
Welcome to the Fitbit Community, @GrauchoMarx, @Conniejo01 and thanks for getting back to us @rwalker82. Thank you for following advised troubleshooting steps.
Please try the long restart:
You can also try changing your tracker's clock face.
Best Answer08-12-2022 01:40
08-12-2022 01:40
Best Answer08-12-2022 10:53
08-12-2022 10:53
I have the same issue and thoight it was normal until speaking with another charge 3 wearer today. Nothing solves it
Best Answer08-12-2022 12:15
08-12-2022 12:15
08-12-2022 15:52
08-12-2022 15:52
Thanks for getting back to us and for following troubleshooting steps @rwalker82, @GraceTr, @Conniejo01.
I understand how frustrating this could be and the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Best Answer08-16-2022 21:43
08-16-2022 21:43
08-17-2022 06:38
08-17-2022 06:38
Thanks for getting back to us and for letting us know that you have tried the steps several times @rwalker82.
Please try contacting our Support Team.
Best Answer08-22-2022 03:13
08-22-2022 03:13
I couldn't reproduce the steps, talked to support and waiting for an answer. It does not look good though...Two years of use is enough for this device to die? 😕
08-22-2022 07:03
08-22-2022 07:03
08-24-2022 02:18
08-24-2022 02:18
So a bunch of us are having this issue (precisely after warranty ended) and the solution is: take a discount and get a new one. Ok, Fitbit, thanks for the discount, but I am kind of skeptical about your products' life...
08-24-2022 03:12
08-24-2022 03:12
08-26-2022 19:15
08-26-2022 19:15
I purchased my Charge 3 for the purpose of seeing how I was doing on my daily walks.
Only problem, I walk outdoors. I never was able to read that watch outside. Inside, no problem but outside, forget it.
I wonder, have they changed the screens yet so they CAN be read outside during daylight hours?
