10-23-2019
21:00
10:40
10-23-2019
21:00
10:40
A week ago I noticed a thin blacked out line running across the middle of my screen. And day by day it's getting worse. Its multiplying and thickening in certain areas. I've had it for about 11 months now.
10-24-2019 01:53
10-24-2019 01:53
Hi @Mimit88 I have flagged a moderator to come and help you
Helen | Western Australia
10-24-2019 08:27
10-24-2019 08:27
Hello @Mimit88, it's good to see you around in the forums for the first time.
Thank you for sharing this information about the screen of your Charge 3 that has blacked out lines. Before considering other options, please make sure that you've tried the standard restart procedure described here.
Also, if you continue to experience the same behavior, follow the steps listed here below to complete the long restart procedure:
Keep me posted on the outcome.
10-24-2019 23:01
10-24-2019 23:01
10-25-2019 09:24
10-25-2019 09:24
Hello @Mimit88, thank you for your reply and confirming that you already tried all the suggested steps.
I've gone ahead and sent your information to the Customer Support team for further assistance, so you should be getting a reply soon. Keep an eye on your inbox.
Let me know about te outcome.
08-08-2020
06:02
15:44
DavideFitbit
08-08-2020
06:02
15:44
DavideFitbit
My Fitbit did the same thing. Lines slowly appeared and got worse over days. Now it's black. I've tried the clock reset and the 15 second reset multiple times. I can't get it working 😭. It's still sending info but I can't see it on the fit bit itself.
Moderator edit: format
08-08-2020 15:44 - edited 08-08-2020 15:45
Hello @Khannolly, thank you for your reply and confirming that you already tried all the suggested steps and that you're having the same problem with the display of the Charge 3. .
I've proceeded to send your information to the Customer Support team for further assistance as well, so you should be getting a reply soon. Keep an eye on your inbox.
Let me know about the outcome.
