12-07-2020
03:52
10:37
AlvaroFitbit
12-07-2020
03:52
10:37
AlvaroFitbit
Very unhappy that after 2 years my Fitbit 3 is basically useless as I cant see the screen any more .
same issue with my wife’s Fitbit .
after reading an number of threads it appears the problem won’t be fixed ... I decided to by the Apple Watch for Christmas... hopefully this will do the job going forward
12-07-2020
10:39
07:04
12-07-2020
10:39
07:04
@DavidC1965 It's nice to have you on board.
Sorry to hear that your Charge 3 and your wife's tracker screens aren't working correctly. You don't mention any troubleshoots so I suggest you restart your tracker by following these instructions.
Let me know how it goes.
Best Answer12-07-2020 10:55
12-07-2020 10:55
Just checking you haven’t accidentally switched on the Sleep setting, which would dim the screen? This is in the Settings section. But also if you Press and Hold the side button there’s a shortcut menu to the DND (Do Not Disturb) and Sleep function. Try switching the Sleep function On and Off, does it Dim and Bright the screen?
12-08-2020
06:11
07:01
12-08-2020
06:11
07:01
@SunsetRunner I hope you are doing fine.
Thank you for the input. @DavidC1965 this is also something to take into consideration so please check these settings on your tracker.
Keep me posted on the results.
Best Answer12-08-2020 07:37
12-08-2020 07:37
I am having the exact same problem. I have done all the restarts etc.. and nothing works. I am also having issues with bands falling apart. I have gone through 8 bands now in the two years I have had this one. This is my 4th Fitbit. Customer service used to be great which is why I have stayed with Fitbit, but not anymore. I cannot afford to be buying new devices every two years. I am looking at other options.
Best Answer12-08-2020 08:46
12-08-2020 08:46
Thanks for the help. That was exactly my problem. Must have hit a wrong button while I was trying to look at info in sunlight and could not see the screen very well.
12-08-2020
09:28
07:01
12-08-2020
09:28
07:01
@runnergirl111 @alma70man Welcome to the Community.
@runnergirl111 Sorry to hear about this issue. I noticed that you already have a ticket with Support so please work with them to find a solution.
@alma70man happy to hear that you were able to find the solution to your issue in this thread and hope you can reach your fitness goals.
I'll be around.
