My Charge 3 shows gray lines on the screen
Just charged my fitbit and on removal from charger the screen has gone grey. Tried reboot it and change clock as per other threads I read on line, no improvement. It's not new but I'm still pretty unhappy as my charge 2 did similar. Would appear by the number of people with this issue that there is a common fault in this unit that fitbit missed in QC.
3 REPLIES 3
Welcome to the Fitbit Community @MarkNewby.
I'm sorry to hear that your Fitbit Charge 3 display is not working properly. Thank you for the information provided and for trying to resolve the issue before contacting us.
In addition to the regular restart, please try a long restart by doing the following:
  1. Connect the device to the charging cable.
  2. While the device is plugged into the charging cable, press and hold the button down for 15 seconds.
  3. The device turns on and shows a battery icon. Two vibrations occur: first a short vibration, then a medium vibration.
  4. The device turns off.
  5. The device turns on and shows a progress bar and short vibrations occur. The progress bar completes. Note: A total of 7 short vibrations occur.
  6. Remove the device from the charging cable. The device shuts down.
  7. Important: Plug the device into the charging cable again.
If you have any question, please let us know.
Yes I've tried that several times and if anything the screen is getting
harder to see.
This seems to be a very common issue with the charge 3 reading through the
community posts!
So disappointed with it as was going to buy the grandkids one each for
upcoming birthdays, reckon I'll be looking to buy alternative ie Garmin if
this can't be sorted!
I have also had absolutely no success with these directions, I have tried it multiple times and a regular, and often restart doesn't help, I have had my Charge 3 for about 5 months since I got it and it started fading after 2 months, My parents were having issues with their charge 3's and 2 of them faded completely, what do we do to fix them now???
