05-24-2022
10:04
14:20
05-24-2022
10:04
14:20
Very suspicious reading all the recent Charge 4 issues. Mine at approx 17 months (xmas gift) seemed to be working fine, and i just added a nice aftermarket band being i was so satisfied. It was holding charge about a week, latest S/W update, latest app, no current changes or concerns or abuses, then 4 days ago on a walk it started. Flicked my wrist to check the time-no display, tap screen-nope, push buttom-buzzes but still no display. Get home and try to sync with phone while on WiFi-taking a while sit tight....failed sync. Try cycle bluetooth off & on-nogo, try restart phone-nogo, try force stop & restart app-nogo, finally hookup to charger via wallwart (though should have had approx 75% charge available)- but no battery/charge in progress display, button press still buzzes. Try resetting device holding button while on charger-finally get a smile face but still no other displays or sync functions (no data at all). Then notice the seeming battery failure too-that is if i disconnect from charger in evening-only operable functionality is buzz on button push-then by morning (haven't tried other disconnect durations) even the buzz is gone until i reconnect to charger. Now at 4 days lost with a "bricked" Charge 4, searching for help here/online to no avail so far.
As a system engineer by profession, i strongly cannot believe this is a random device failure without involvement of some undesirable S/W update being the root-cause issue here. (Note that the last mysterious issue i had a couple months back did get resolved after an update.) OR, somebody did a really good job planning-in device mortality based on the number of similar symptom comments I've seen. Whereas i enjoy using the device (having had several versions now) and having the ongoing data to review, i cannot justify sinking more money into a brand that seems to fail at such a rate as these do. I will either go without or be a much more careful shopper next time!
05-29-2022 19:32
05-29-2022 19:32
Thank you for visiting the Fitbit Community, @Fitcraz.
I’m sorry to hear that you are having difficulties with your Fitbit Charge 4. Your time while dealing with this situation is highly appreciated.
If your Tracker doesn't turn on, please follow these troubleshooting steps.
If you followed our recommendations without luck, the best way to get help for this problem is to chat with us online or give us a call. Please click here to get connected.
Have a nice day.
05-30-2022 18:35
05-30-2022 18:35
I disagree with the moderator edited Subject line "clarifying" the topic, it misses the real topic that my Charge 4 has totally failed at barely 17 months old, almost instantaneously going from fully functional to total failure whether connected to charger or not! NO data/sync, NO display (except for smile face upon device reset), NO sensor lights on bottom. ONLY apparent functions are smile face already noted and button buzz/vibrate while charging or during the very short duration until the battery totally fails (which had been lasting approx a full week before the device failed). All fix attempts/diagnostics thus far have been fruitless. Reading the board shows numerous similar instances of what appears to be a common failure mode and timing though some point to fewer symptoms whereas mine appears to be a close to TOTAL failure. I and others have also noted the similarity of failure mode and timing, and the common suspicion of a Fitbit software/app issue being the real possible cause. The "Best Answer" then misses the mark in a similar manner as it fails to address the real issue/subject.
