03-09-2019
06:30
17:14
03-09-2019
06:30
17:14
My fitbit Charge 2 won't start, i tried charging it and for 2 hours it did nothing, i push the button on the side, doesn't work, when i move it, it won't start those 2 green lights on the back of the watch, help me, thanks.
03-10-2019 09:24
03-10-2019 09:24
@CezarStefan A warm welcome to our Community! Sorry to hear that your Charge 2 isn't turning on and thank you for troubleshooting this. I would add that you can try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves.
Let me know how it goes.
