My Fitbit Charge 3 is blank and will not reset
Hi,  got my Fitbit Charge 3 as a present. Was gping all well and have used it for less than 2 weeks and when i woke up this morning,  the display is blank and no lights at the back. Tried restarting by charging,  hold for 15 seconds, release and charging again but will not work. Tried holding for 8 seconds also will not work. Help!
19 REPLIES 19
Hi @JSAJames  One more thing to try. Have a go at changing the clockface in the app. If that doesnt bring it back to life please come back here.
Community Council Member
Helen | Western Australia
Hello @NellyG . Thank you for your kind reply. i tried launching the app and went to the clock but was not able to change as it mentioned that My device is not connected.
I had it charged to 100% yesterday As well so i am sure is not the battery problem as well.
How can i do next.? Thank you once again.
I am experiencing these exact same issues. So frustrating! 😞
@JSAJames  I will flag  your post for a moderators assistance.
Thank you @NellyG . That will help me and @ChloeSnickel A lot. Cheers.
@JSAJames Welcome to our Fitbit Community and it's great to see you here @ChloeSnickel! I'm happy to assist you with your Charge 3 trackers since their screens stopped turning on. By the way, thank you for troubleshooting this issue before contacting our forums.
I'd like you both to try the troubleshooting steps that are listed in this help article. This article contains the restart process but you can skip if if you already tried it. After trying the steps, charge your Charge 3 trackers for 2-3 hours and see if they come back to life.
Thank you so much for your help @NellyG!
Keep me posted on the outcome! Smiley Happy
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
Hi @JuanJoFitbit , appreciate your reply but as mentioned, i have tried what was stated but it is not working.
Nothing to do with the battery and i tried resetting as recommended. Can you advise?
Hi I have exactly the same problems.  Tried the 8 second and 15 second resets - nothing.  Total discharge, full re-charge, a small charge - same.  The device vibrates on pushing side button, but no screen.  will show the re-boot bar and sometimes holds it on the screen and needs a re-boot to clear.  Sometime goes to smiley face and won't clear, sometimes it will.  No clear pattern.  It will not connect to my App so cannot do anything with the clock face.  I have the Special Edition and it was a Christmas present so its not very old.  Its never been wet, just use for step tracking and link to iPhone for messages etc.  Getting very frustrated not being able to use it.  What do you advise please?
Hi @JuanJoFitbit Can you assist on this?  I understand that Fit Bit do not have any repair centre as well.  Thank you.
I'm having the exact same issue with my Charge 3.  Nothing is working and it will not longer pair to any device.  Not sure what else I can do.
Dear @NellyG , can you be so kind to check with other moderator as it seems @JuanJoFitbit Is not able to assist. I have tried what was suggested and nothings seems to work. My fitbit is just dead,  not vibration, motionless and not connecting at all. Thank you and apologies for disturbing you on this.
Hi @JSAJames  I have flagged again and hopefully a moderator will be along soon.
Same here. Charged battery to 100% last night. Worked fine. Now, will not turn on. No lights on back. Fitbit app cannot find tracker. Cleaned it according to instructions. Will not reboot after multiple attempts. Clock face method did not work. What now?
Same thing happened here.  I eventually got it to work but only briefly before there was continuous vibrating and I couldn't make it stop. Not sure ....may just go to different product now to track steps etc since this is the 3rd Fitbit I'm buying in 3 years!
Welcome to the Community Forums @TEHall@eiwacat  and @Balmieret ! Great help @NellyG. Thanks for getting back @JSAJames and @LisaM64Sorry for the delay.
I really appreciate the time you've invested on the troubleshooting steps that you've tried with your Fitbit Charge 3. Sorry for the delayed response.
@TEHall @JSAJames @LisaM64 I've requested to our Support team to create a case on your behalf. You should soon receive an email from Customer Support. @eiwacat Thanks for reaching out our Social Media team to inform about this issues with your Charge 3. You should also receive a follow up email shortly.
Your feedback is greatly appreciated. Please le me know if I can assist you with anything else.
I'll be around.
@JSAJames did this get resolved? I have the same issue only mine isn't turning on even briefly, finding for a sync or frankly anything instead of vibrating when button pushed.  If they fixed for you, would be wonderful to know how?
Thanks!!
Hi.
They send a new one to me. Just email to them about the problem. They will
ask you when tou purchased and how long you had it for.
Hope this helps.
Best Regards,
James
Same here ,no matter what I've tried will not come on or sync with phone.
@JSAJames thank you.
@Moderater can you please help me reach someone? Quite depressed as was a gift from my kids.
