11-23-2019
17:48
19:49
11-23-2019
17:48
19:49
My Fitbit Changed the time so I went to sync and it said “device not found” then I deleted the charge hr off my phone and I went to download it again but it just won’t sync.
11-24-2019 15:51
11-24-2019 15:51
I have a ZBlaze and my Fitbit charge HR will not sync for notifications. I have tried literally EVERYTHING. It's never worked. Can anyone help me?
11-26-2019 09:00
11-26-2019 09:00
I am having the exact same problem and have tried all the 'fixes' I've been able to find. All I get now is 'device not found'. I always kept it on 'All Day Sync' but something changed and it just won't work at all now. I cannot find a way around this problem. I have a Galaxy Luna J3 that is less than 6 months old. The Fitbit still counts and all, just won't sync.
11-27-2019 18:28
11-27-2019 18:28
12-01-2019
06:13
05:55
AlvaroFitbit
12-01-2019
06:13
05:55
AlvaroFitbit
Same problem unable to sync for 4 days, tried everything including removing tracker from the app. Now I cannot connect the tracker back to the app so where that leave me?
Moderator edit: remove all caps
Best Answer12-02-2019 22:50
12-02-2019 22:50
It means that you need to fix the sync issue before the app will find the tracker.
First step is to remove the tracker from the phone.
12-02-2019 23:12
12-02-2019 23:12
Eventually after a day of removing and re-installing both app and tracker something just clicked and all is good now. , syncing on laptop, phone and tablet. . It was like the proverbial, try, try, and try again.
Many thanks for your reply, its nice to know that someone is always listening and there to help.
Best Answer12-02-2019 23:57
12-02-2019 23:57
Please do not yell by typing in caps.
Also be aware that if the tracker is connected to one of your devices, you may not be able to sync through a different device.
Best Answer12-05-2019 10:53
12-05-2019 10:53
Only connected to one device. Sorry that is not the problem but thanks for trying! It may help someone else.
Best Answer12-05-2019 10:54
12-05-2019 10:54
Already tried uninstalling & reinstalling the tracker. Still won't sync 😞
Best Answer12-05-2019 10:55
12-05-2019 10:55
Same problem here. I uninstalled then attempted to reinstall my Fitbit and now it says that it cannot find the device at all.
Best Answer12-05-2019 12:06
12-05-2019 12:06
Same problem, phone in my hand and tracker on wrist but neither can be found.
