06-10-2022
16:47
14:20
06-10-2022
16:47
14:20
It's only a few months old. I plug it it and it comes up as charging but not going above 3%. It completely ran out of charge before I plugged it in.
06-12-2022 10:09
06-12-2022 10:09
That’s awesome @Sh3lley! 😃 I’m happy that it worked and you and your up and running again. Please consider marking my post that provided you with the solution as “best answer” as doing so helps anthers who might be experiencing the same issue find answers quicker. Happy Stepping!
06-10-2022 19:31
06-10-2022 19:31
Hello @Sh3lley
I would try allowing it to charge for a couple of hours to see if the issue corrects its self. If the problem persists try restarting your Charge 4. You will not lose any data doing a restart. While it’s being charged press and hold the button on your Charge 4 until you see a smiley face appear then release the button. You will feel the Charge 4 vibrate indicating the restart is complete.
😉 I’m hoping this resolves the issue and provides you an answer your charging problem. Please let me know
06-11-2022 07:01
06-11-2022 07:01
I can't restart it (so no smiley face) as that's not working either. Cleaned the pins/connectors on the watch and charger but still not charging any more than 3%. Been like this for nearly two days now ☹️ it's only a couple of months old.
06-11-2022 11:32
06-11-2022 11:32
Oh my @Sh3lley
I’m so sorry restarting your Fitbit Charge 4 didn’t help. Great idea to check your charging cable pins! Can you try at least one more thing? Can you try changing your Charge 4 clock face through the Fitbit App? I’ve seen that sometimes help.
06-11-2022 23:10
06-11-2022 23:10
Clock face changed along with charger plug and all good. Thanks
06-12-2022 10:09
06-12-2022 10:09
