02-05-2022
02:30
15:43
02-05-2022
02:30
15:43
I’ve just bought a charge 4 Fitbit. I used to have an Alta. Now when I go to log in they say this email address is taken by another user. How can I not use my email.
02-06-2022 19:07 - edited 02-06-2022 19:36
Try logging in, do not tap Join Fitbit.
You know that the User does exist, you are posting as this user.
If you have forgotten the password, check your saved password list
Or tap forget password,
Best Answer02-05-2022 03:20
02-05-2022 03:20
Hello @Dindaeng
Sorry to read this. Could you please detail a bit more ? When you login where ? On the app on your phone or on the website ?
Is it the same account you were using with your Alta ?
Best Answer02-05-2022 05:50
02-05-2022 05:50
Best Answer02-05-2022 11:10
02-05-2022 11:10
I have a feeling that maybe a second account was created or tried to be created, and since the email must be unique, it refused. You said you changed your password ? To change a password you must log in so somehow it worked to log in ?
Best Answer02-05-2022 16:07
02-05-2022 16:07
Best Answer02-05-2022 20:52 - edited 02-05-2022 21:06
It sounds like you are trying to create a new account with your existing email address, rather than logging into yourfexisting email.
The fitbit account that you are posting from was createdhin 2014. Please go to your settings page where you will find the email you want to use. You probably will be able to find the password in your saved password list.
Then log in.
Best Answer02-05-2022 21:11
02-05-2022 21:11
Best Answer02-06-2022 11:15
02-06-2022 11:15
There is something I do not understand here. If you can access your Setting page then you are logged in already. So why do you need to change the password for an account you can access ?
I still have the feeling there is a misunderstanding between creating a new account and log in to an existing account.
Best Answer02-06-2022 18:25
02-06-2022 18:25
Best Answer02-06-2022 19:07 - edited 02-06-2022 19:36
Best Answer02-07-2022 02:29
02-07-2022 02:29
